Help no fuel to filter
- Replies 32
- Views 8.6k
Bugman123 10 posts
Mopar1973Man 6 posts
LiveOak 5 posts
guesswho512 3 posts
Last night i install a fuel psi sending unit in my vp44 at the check valve, i remove it from the vp and installed a banjo bolt then the psi snubber, then the sending unit. When i went to start it, i bleed air at sending unit to get it to start, then back up parked until the morning to finish the inside stuff then. Once i was finish it would not start. bleed again, but did'nt get any fuel. remove banjo at back of filter and i did the crank-no-start thing for the pump to start and it was but nothing coming out of the banjo at all. Was on a slope driveway and I had 1/4 tank of fuel, went and got 5 more gallons, still nothing. I then went and fired up the air compressor to put some psi into the tank, then i got fuel all the way to the vp44 when everything was put back together. The thing is, it was running find until i started to put in the gauge. I was in battle with myself the the wife on which one first, Gauges or the lift pump, now i think i have to tell both
, not in the budget. Am i missing something:cookoo:?
