7x0.0085 +75HP SAC Injectors from DAP
- Replies 26
- Views 12.7k
Mopar1973Man 8 posts
notlimah 5 posts
TFaoro 3 posts
jlbayes 3 posts
Boost is NOT a good reference for cylinder pressures. It depends on timing, boost, temperature, etc. If I were Mike I would at least check one of the head bolts to make sure the gasket hasn't se
Was over 60psi with stock head bolts & gasket, no way shape or form a good measurement on when they will go. I love how my corruption for power is spreading on here.
I never plan on having the power you do but I know every time I add a little more it is fun and addicting. Just as much fun to watch Mikey with the bug.
Finally, the injectors came on Thursday. I waited till Saturday to come home so I've got the weekend to install the new injectors. Very clean looking injectors, fresh copper washers already supplied. I was kind of shocked though, as posted on DAP page...
https://dieselautopower.com/diesel-auto-power-75hp-performance-injectors-7x0-0085-sac-vp7x85sac75/
The injector connector tube removal tool was missing and o-rings for the connector tubes was missing. What you see in the photo is all I got. Kind of disappointed to find out that the crossover tube o-rings and the tool were not in the package.
So I really do hope these babies are clean running... We'll find out very soon as of tomorrow.
