Exhaust Brakes and head gaskets
- Replies 7
- Views 2.9k
Me78569 2 posts
Mopar1973Man 1 post
dripley 1 post
Dieselfuture 1 post
Popular Days
Eb are not hard on headgaskets assuming you are not injecting fuel when using one going down the road. The eb is just creating a pumping loss in the engine. There is far less cylinder p
Correct. 12V motors came with weaker springs and have a larger surface area per valve.
By blocking the exit of air from the engine you force the engine to compress pressurized air during hte exhaust stroke rather than allowing that air to exit . This creates a large pumping loose in
Simple question...are exhaust brakes hard on head gaskets or other downsides to them?
