- Replies 17
- Views 2.7k
KRob 8 posts
Mopar1973Man 5 posts
dripley 1 post
trreed 1 post
This is not a APPS problem too many look at the APPS first. I would start with AC noise testing from the alternator. Check for any error codes present on either computer. Is there any modi
First off you never test at the battery... Only at the alternator. So the RED probe goes to the BATT stud on the alternator and the black probe goes to the case of the alternator or the negative batte
I originally posted this on Cummins Forum, any thoughts or ideas would be very helpful.
Truck very intermittently (probably twice in the last month), typically in traffic, at low RPM and low throttle input will start rev ing up to about 2200 RPM and then die. If I immediately try to restart it it will not catch. If i turn the key off and let it sit for a 10 seconds or so it will start back up no issue.
So low RPM, low throttle pressure it will start pulling, it will gradually pull until about 2200 RPM and then die. Manual truck so once i notice the issue i push the clutch in, once i push the clutch in it will rev to up to about 2200 RPM over about two seconds time period.
Several months ago i had numerous electronic issues which this was one of them. Replacing the PCU/PCM (cant remember which one it is on this one) and the alternate, seemed to fix a no bus issue, and voltmeter periodically flat-lining.
Topic was covered in this thread: No Bus & Voltage Gauge Dropping Off & Periodic Revving and then Die-ing
No Bus & Voltage......
All of those issues have gone away except the rev ing issue.
XZT+ is still hooked up, but will probably un plug it in the coming days.
Truck has had a Timbo app on it for 100,000 miles probably. Gut tells me it has something to do with that but i ask for your advice.
2001 Dodge Cummins HO (Six Speed) So Pump, XZT+, timbo apps.
