Well I hate to say that word head gasket, but I got oil bubbling out of front right, by head bolt just to the right looking from front( I got ARP's from po. ) It bubbles tiny little bit from head gasket and running down front cover, not enough to drip on the ground yet. Wondering where is a good place to get parts from, like a gasket set and whatever else I may need. Though about mabe going through the turbo but want to up size to at least a hybrid, so might just leave it be. Another thing is I already have ARP studs but not sure which ones, how do I tell, I know there is more than one choise. Will need to know torque on them when putting the hradon backnowledge on. Can I get the head off without removing studs looks pretty close. I will take the head to machine shop to surface and maybe even check for cracks, since I heard 24 valve heads like to crack sometimes. Will probably do a valve job and new seals at the same time. Not sure about ringing the head. The T at the back of the head, what's the best way going about it. Thanks for any advice. I will probably be lining up parts for a while and keep driving the truck,  unless it gets real bad or just blows out. I'm guessing there is an oil passage somewhere up front, just not sure how it's getting pushed out, oil pump pressure? Does it have something to do with coolant, I don't think I'm using any, maybe a little I had to put about a quart in the other day, will keep an eye on it.
Edited by Dieselfuture
  • Replies 266
  • Views 46.7k
  • The people that tell you to sell old and buy new know nothing about fixing vehicles nor do they work on them. I work on hybrids and electrics. There is a huge disconnect between the end user and the v
  • Dieselfuture
    Dieselfuture
    Alright guys and gals, got my turbo today. I'm giving it 9 out of 10 and this is before driving the truck. Came with cnc machined beer opener. On first glance it looks good, on closer observation I've
  • Dieselfuture
    Dieselfuture
    Trying to get valves out so I can take this thing in to shop. What's the best way to release keepers, I usually slightly tap on them and they  come apart, but these are stubborn. @TFaoro @jlbayes @trr
I feel much better now, thanks guys. That's why we hang out here maybe  (part of reasons at least ) we understand each other and have things in common. Things that you just can't explain to some. Got to have it in your blood :burnout:
14 hours ago, TFaoro said:
They're always mad about something. Since I got the electronics out of it, mine has been much better about being alive. I'm slowly getting it beat down.
I used to have couple of duce and halfs, ( friend of mine has about 60 now :thud:he chops them up and sells them as 4x4 on 46s or 52s) I kinda got him into this but he loves it. drove them every where got right at 10 mpg no matter what and lots of confused people. All mechanical I loved it, but.... 55 is about top speed unles on 52s then you could squeeze 70 maybe. not very comfortable and military screwed up not putting lockers in and using **** for tires thats how supersingles ca me about. Got them at government action for peanuts,  took forever to get them legalized/registered and had to sign a form that said if dot ever decide they are not road worthy they have a right to revoke plates. Least to say I had fun with mine, I left them as 6x6 and instead chopped a junk one up for parts and lifted my 76 chevy, learnd a lot there. I can keep going on this story but here is a link to my chanel, you can kinda see my life pattern till I got married and hardly any videos lately. Now waiting for kids to grow up a bit and slowly get them of wife's iPad onto a quad to start with.
  • Popular Post
The people that tell you to sell old and buy new know nothing about fixing vehicles nor do they work on them. I work on hybrids and electrics. There is a huge disconnect between the end user and the vehicle.
Somehow they forgot that electricity comes from mainly burning coal and small percentage of hydro and solar, o and environment friendly nuclear.
By "work on" you mean burn to the ground because there's not enough room to get your hand under the hood?
13 hours ago, CTcummins24V said:
I know that one. Our conversation usually ends in "just sell it"
Just wait... Get a 3rd or 4th gen and start planning on injector changes every 100-150k miles. Looking at around $4,000 for quality set of new injectors. If you think you can just over look that fact so many people lose an engine over bad common rail injectors. Then there are people driving around with the grid heater light on. High return flow from bad injectors kind of a check engine light of injectors.
So now we whine about $1,100 for injection pumps every 100-200k miles. Then if you happen to wipe out a CR engine then look towards about $6.000 to be rebuilt.
:thud:I'll be keeping mine as long as I can
Minor detail. Or how lithium is obtained.
Most stuff we do is fairly accessible. Some of it won't be due to design obviously. Amazing when a minor connection issue on the bus will bring a whole car down.....
17 hours ago, jlbayes said:
Y'all do not know mad. I promise.
Bet me!
I need a duce. Business vehicle!!
Edited by TFaoro
I always wondered what a battery change in one of these vehicles costs.
i very seldom hear this mentioned, I only hear about the 0 emissions. It is true the car does not but the power plant sure does.
One thing most people won't tell you that hybrid doesn't travel too far without a charge. From what I've seen is about 15-20 miles tops. Out where I'm at they will not survive even one trip to the store or drive to work it's too far for any hybrid.
I'm seeing about $1,500 to $2,000 roughly. Average life span of the battery is about 100k miles.
Unless you have a power plant like mine. Solar and Hydro. Zero Emissions...
Then down the road from my place is another hydro power plant. The majority of Idaho power comes from Oxbow dam on the snake river.
https://en.wikipedia.org/wiki/Oxbow_Dam
19 minutes ago, TFaoro said:
Bet me!
Done.
Depends on who the supplier for the battery is. I can only comment on what the cost is for the cars I attend to. 15k for a reman, 30k for a new and 8k (different supplier and car) for a new. These do not make 100k miles either lol
Edited by jlbayes
Are you working on Teslas?  I know the Prius (Mike this word needs to be added to the bad word filter) battery is around 2K
Someone I know has a tesla, they get about 300 mile range depends on driving stile. There is a guage like instant mpg type, more accessories you use faster you go etc the worst of it is. But they put fill stations for them free of charge if you own one usually next to bigger stores, so you plug it in and go shopping. Price tag on average one is around 100k , these people are software engineers, so there is that. They live in their own words.
This is a post of one of them bubed dueces. His prices definitely went up over the years. I was able to buy one for 7-8k 10 years ago in really nice shape, with a winch and a heater, Hard or soft top. You can build one but takes some time and equipment to do it.
https://cedarrapids.craigslist.org/cto/d/custom-deuce-truck-x-trailer/6208956003.html
No need for a bobbed one, I need a whole one. I'd use it as a business truck to take products to shows. CL has them for around 10k usually
Yeah I sold mine for 3500,should of kept it but no room.
Negative. FCA.
Pardon my ignorance, but what FCA vehicles are hybrids or fully electric?  I haven't heard anything about those..
