- Replies 12
- Views 2.6k
notlimah 2 posts
kzimmer 2 posts
Arodrigues29 2 posts
trreed 2 posts
Took everything I could apart as far as grounds go again and reflashed the Quad. No luck. I jiggled the positive cable to my PDC by happenstance and sure enough it was loose. Seems like the nut backed
How do the wires and connections in the power distribution center (PDC) look? Start with the main cable from the left side battery to it.
high voltage is normally a bad ground in my experience. Flash the Quad for good measure.
2001 24v 5spd 4x
My truck struggled to start slightly and clunked at 2K rpms in second pretty loudly and before I could pull off it did it again 1800 rpms in 3rd this time my headunit, trailer brake controller went off and back on and my lights started doing the rave party flash. Shut the truck off, checked my battery terminals everything looked cherry started it back up no issues. About 5 mins from home my gauge lights started flickering and my volt gauge spiked to 18. I had a battery terminal that was suspect and new batteries sitting around so I tossed them in, wire brushed the connections. 2 weeks of perfect driving and today it happened again, skip in second, hardish start headunit flash. This time when I turned the truck off it wouls not restart, no hazards, no power whatsoever. Took off positive battery cable on drivers side battery and reapplied it, truck fired right up w/ engine light for high voltage. Truck got me home, lights a little flickery. I cleaned all my grounds within the last 6 months, alternator tests good. Direction?
