Custom Quadzilla Tuning R & D Thread
I didnt want to mix up the threads by posting unrelated information so I figured I would start a new one.  This thread is for figuring out what works and what you find your truck likes.
I did some more datalogging as of late and found that a more aggressive timing curve later in the rpm band, say 2500 + rpm, seems to pull harder up top.  Previous I was running tunes that maxed timing at 26*.  I took 2 tunes copied them and ran them back to back on the same stretch of road, same conditions.   I was not using wiretap for this so I will leave those details out
First Tune 29* max
Quote
Race 29*
Number of Power Levels 6
RPM Limit 3700
Valet Mode
Maximum Valet Mode Power 35
Timing Parameters
Fuel Load Timing 1
Low PSI Timing Reduct 5
Timing Reduct Scaling 80
LightThrottle Timing Adv 1
Light Throttle Limit 35
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 24
3000RPM 27
MAX 29
Boost Level Fueling - CAN Bus
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
Second Tune 26* max
Quote
race 26*
RPM Limit 3700
Valet Mode
Timing Parameters
Fuel Load Timing 1
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 22
3000RPM 25
MAX 26
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
The interesting thing is the tunes are the same except for the timing above 2500 rpm.  If you look on the graph rpms hit that 2500 rpm mark at about line 20-21, each line is ~.3 seconds so 3 lines = 1 second.    You can see where timing jumps and also where boost jumps.
Now keep in mind the graphs are not exact so take them with a grain of salt, but everything appears to show that the tune with higher timing up top gives faster time to 50 mph, and a faster ramp up of boost.  The higher timing tune appeared to reach 50 mph nearly 1 second faster.
as always studs are a good idea, but I am fairly sure anyone can run this timing above 2500 rpm.    If people are not blowing their heads off left and right with other tuners then there is no reason why this type of timing curve will hurt with the Quadzilla.
Food for thought, open to other thoughts.
  • Replies 477
  • Views 90.1k
  • and a spare room for me to crash in while I tested about 50x different tunes and setups hahaha
  • Close your eyes and click it.  That's how I order truck parts these days.
  • I think with these vp44 trucks, the biggest downfall here is no 2 are the same... I feel like the quality control was subpar. It seems like 5 identical trucks would behave in 5 totally different ways
If you like I will make min wiretap apply no matter what lololol.
Let me know
I don't think it would be necessary for my application especially considering the manual, but I'll let you know when I have them in.
3 hours ago, Me78569 said:
adding wiretap is like mutliplying the canbus signal by up to ~%30
IE: canbus only 0-4095  if we add wiretap the upper limit extends to ~5300 but that 1200 of extra duration is done by bypassing hte psg.
So why limit it to 4095 from factory, to prolong the life of VP. I know a lot of things are designed to run at 80%
I am sure the fueling solenoid is rated to run at x duty cycle, being 4095 command.  Wiretap just holds it open longer, I am sure beyond the rated duty cycle
That wouldn't help my situation anyway. My stalling issues happen after letting off the throttle after a stab. The truck factory Defuels after letting off the throttle to get the rpms back to 800, undershoots, and attempts a recovery. The issue is always at TPS = 0.
I started noticing tonight that it takes longer to start. A tad bit worse cold starting than the 7x.014's were at 340 bar, which cold started excellent. Actually unbelievably well. There's a stumble now and a tiny bit more cranking. Not a ton but noticeable.
Also, I noticed tonight that when up to full operating temps, it starts significantly worse. Extra couple seconds of cranking and stumbling. But when running, it's fine. And it drives exceptionally well. Definitely the best running so far.
All in all I think the moral of the story is increase pop until just before any introduced issues become a pain in the ***. I'm thinking that's going to be around 350 bar in my case.
What is your lift pump setup? Is the lift pump running while you are cranking?
That's the highest number a 12 bit bus can represent..... See
https://en.wikipedia.org/wiki/12-bit
You know how 1 bit binary is 0,1, where 1 is the largest number it can represent.
Walbro 392 mounted on the frame rail, 1/2" lines (mostly) and a sump. It primes with key on and after a crank but I've never actually attempted to listen to it while cranking, pretty tough. Fuel pressure is always good though. My only gauge is on the quad, which is on an android head unit, which loses power while cranking.
2
Hexidemical its equal to FFF (4,095 Decimal) 1000 hex would be 4,096 decimal.
0 1 2 3 4 5 6 7 8 9 A B C D E F 10 (I just counted to 16 in Hexadecimal)
Yeah, I'm doing this because I love to play with numbers and different number systems. :whistle:
Ya its interesting stuff, I had a 5th + 6th grade teacher who taught us how to count in base 2 to 10. I'd like to know more about it, like what you mentioned above. Kind of an inperson topic tho. I often wonder why we dont / wish we did have an mirc channel for the frequents of this board. That was kinda neat back in the day /w the Techspot(.com) fellows. (and other underground warez peoples, back before p2p when hacking corporate ftps was a real thing)
I did some wep encryption packet sniffing with aircrack-ng and got the passwords in hex I believe it was. I wanted to convert them to plaintext but never figured out how, because windows would take the hex & accept it to connect.
Edited by rogerash0
If it's of any interest to you guys I did just get a bunch of quality information on pop pressures and the benefits and consequences of raising it. Let me know if it's pertinent or has any interest to you and I can shed some light at lunch time
PLEASE let us  know what you heard.  also please ensure you keep and open mind in terms of what you were told vs what we are finding.  I will do the same from the other point of view.
 I second this.
I started by mentioning I thought about raising pop pressure to 320-330 bar to help with idle and off idle haze from poor atomization from large injectors, and he responded with "that's a bad idea"
Then I asked what the negative consequences of upping the pop pressure was and he said "stalling is the main issue, It’s more pronounced in an auto though. There will be zero benefits to raising the pressure. You’ll lose power as well."
I brought up the idle haze again and atomization again and he said "The problem isn’t atomization. Most confuse intensity for atomization. Atomization is mostly controlled by the relationship of the needle and nozzle."
I then asked how much timing would be lost due to higher pop and he said "Not significantly no. It will shorten duration. In effect making quantify injected less." I mentioned with the quad wire tap settings you would likely be able to pull back some of that duration and he said "not all of it, it's still a mechanical injector"
Weston is not very open to the idea, have you read the thread I had on Compd?   He admitted that increasing hole size decreased the ablity for the injector to spray as efficently at low rpms.  He said increasing pop pressure would help that issue, but he said he didn't see the point.
my truck idles EXACTLY the same as before the increased pop pressure.  Kzimmer has no issues with idle and stalling at 365 bar.   we can force the truck to stall, but it takes REALLY bad habits to do so.  Keep in mind my converter is also a "super low stall" from revmax.
wiretap or more canbus will hold the fueling solenoid open longer, mechanical or not.  This will push more fuel through.
http://www.competitiondiesel.com/forums/showthread.php?t=197943
Edited by Me78569
I haven't read that, I have never been much into compd lol, do you have a link?
I updated my post.   No one was very open to the idea and refused to look at any data.   pretty sad thread when it comes to trying to know more about how things work.
Just a lot of "those injectors are too big" and "you won't gain power " "you should listen" yadda yadda yadda
Thanks I'll check it out tonight. I still feel like people can't comprehend the capabilities of the quad and what things may be possible now that weren't in the past...yes they might be old and outdated, but the technology advancement of the v2 and the adjustability has made things that never used to work, now work flawlessly... I think their is hidden potential that some people don't care to find because they are old and "outdated" trucks that aren't sought after by many
I honestly dont know where the rumor of increased pop pressure = stalling issues,  I dont htink it is pop pressure, I think it is fueling being pulled to rapidly.
My testing just doesn't support pop pressure being the reason for stalling.  My truck should be the worse in terms of this issue.
I just read that thread... Its like I wrote a page out of it in the info I posted a little bit ago... Lol... I think when I get some money I'm going to get some 7x.013-.014 set to 320-330 bar from Weston or Ryan haley and get rid of the crap I have now.. I'm over these 6 home
Hole junk injectors.. I would like to send them to a 3rd party and see what they really are....
