Quadzilla iQuad bluetooth issues
Ok. I've still got this issue and very annoying. This is an LG G5 phone and its brand new not even a year old.
Now the issue is Bluetooth is hanging up on any custom tunes. So if I do like I normally do on my trip back and forth from Ontario, OR. I'll set up at home and fire up the iQuad app but it might nearly 20 miles of shutting down and starting up before I get iQuad to hook up on bluetooth. So like every 4-5 miles I shut the app down and fire it back up. I'll get a quick message about couldn't connect to device. By the time I get to about New Meadows 20 miles away it might hook up.
Now if I want to for sure hook up first time then fire up iQuad switch to DEFAULT tune, then shut down iQuad. Now fire back uo iQuad it will hook up in under 30 seconds typically. Then I can switch to my custom tune without an issue. If I shut down the engine and restart I might be back to fighting it and might now. Most times on my trips I'm stopping to eat somewhere so I shut down the iQuad and go in with my cellphone to work on the web site. Now I'm back to the bluetooth fight again.
  • Replies 57
  • Views 22.7k
  • Quadzilla Power
    Quadzilla Power
    I just posted this in a different thread, but I can go ahead and make a copy of it here as well:   OK, here is another update. The Beta version of the app (for all of you with Beta access) n
  • Quadzilla Power
    Quadzilla Power
    We are always trying to improve things to make them better. Since the last post of this in November, several things have change and updated including both the app and the base level tune that we are u
  • sounds like you have bad solder joints in the Bluetooth unit.     @Quadzilla Power
That was happening on my Galaxy S7 as well. Reinstalled. All good.
a lot of times this will happen if you have a tune selected then you move to a different profile and the new profiles tune settings are different.
When you switch profiles always select "default tune" first that will ensure that when you connect to the new profile it sends the default command rather than all of the tuning variables.
Good to know, I've never loaded default tune always my custom one.
I've been struggling with connection issues again lately. Can't seem to nail down that problem, it'll be fine for a week, and then take 10-20 tries every day for a week. The fuse tap seems loose and flakey so I'm going to replace it with something more solid, however when I can't connect the quad is still controlling fuelling so I don't know if that's the problem.
-Kole
The more I fart with it the worse it is, if I just leave it alone it always connects reliably
Mine is still randomly hit / miss. Some days it hooks up everytime. Other days you have to start the app, shut it down, start it again, shut it down again. It like it does nothing. Not even attempting to hook to the bluetooth. Then eventually it grabs and connects.
Mines the same way. Sometimes takes a while to get it connected so I can see my gauges
Not sure where to ask this but what app do I want from app store 3.2 or 3.3 I have android. Just lost my phone and trying to get this one set up, last time I downloaded app I thought there was only one.
I don't think any of them will cause issues.  I only see one app in the store.
Screenshot_2017-11-01-05-48-37.png looks like 3.3 / vision is for newer vehicles
Edited by Dieselfuture
That 3.2/3.3 you are seeing us a user rating out of 5 stars. I think the app store version is .39, the one on this site is .40(56).
  • 3 weeks later...
Connection issues have been very frustrating the last couple weeks. Whenever I get into the truck it takes several key cycles and often several minutes to get the app to connect. Often throw a few android reboots in there too for good measure. But here's the weird thing... Whenever this happens, android Bluetooth manager shows a connection.
Today I went stopped to fuel up, quad running. Shut the truck off (android shuts off too). Started the truck, android boots up, no connection in app. Took 5-10 minutes of messing around to get a connection again. It's a crapshoot whether or not it'll connect.
Edited by kzimmer
are you running the app version that shows the tune apply on key on?  It will count through the number of variables and if they apply
Yessir. When this happens, the tune apply progress stays at zero, and usually flashes "device disconnected" I think. I can't remember the message for sure, but it flashes briefly once and fades away.
Edited by kzimmer
  • 5 months later...
Any updates on fixing this...im ready to buy a quad and this isnt making me too impressed
Ok thanks.since i got you here will my high idle kit i got from you be disabled if i buy this quad?i love it by the way
