Quadzilla iQuad bluetooth issues
- Replies 57
- Views 22k
Mopar1973Man 15 posts
kzimmer 9 posts
Me78569 8 posts
Quadzilla Power 8 posts
I just posted this in a different thread, but I can go ahead and make a copy of it here as well: OK, here is another update. The Beta version of the app (for all of you with Beta access) n
We are always trying to improve things to make them better. Since the last post of this in November, several things have change and updated including both the app and the base level tune that we are u
sounds like you have bad solder joints in the Bluetooth unit. @Quadzilla Power
Ok. I've still got this issue and very annoying. This is an LG G5 phone and its brand new not even a year old.
Now the issue is Bluetooth is hanging up on any custom tunes. So if I do like I normally do on my trip back and forth from Ontario, OR. I'll set up at home and fire up the iQuad app but it might nearly 20 miles of shutting down and starting up before I get iQuad to hook up on bluetooth. So like every 4-5 miles I shut the app down and fire it back up. I'll get a quick message about couldn't connect to device. By the time I get to about New Meadows 20 miles away it might hook up.
Now if I want to for sure hook up first time then fire up iQuad switch to DEFAULT tune, then shut down iQuad. Now fire back uo iQuad it will hook up in under 30 seconds typically. Then I can switch to my custom tune without an issue. If I shut down the engine and restart I might be back to fighting it and might now. Most times on my trips I'm stopping to eat somewhere so I shut down the iQuad and go in with my cellphone to work on the web site. Now I'm back to the bluetooth fight again.
