No start after fass install
- Replies 12
- Views 8k
Mopar1973Man 3 posts
LiveOak 3 posts
Towrigdually 3 posts
dripley 2 posts
Is the fuel squirting out of the lines or just oozing out? If it's just oozing out them more than likely the VP44 still has air in the pump. Typically it will take two rounds of 30 seconds of cranking
Is the pump (lift pump) coming on for a full cycle when you just bump the starter and release the ignition key?
Prior to entering the garage the truck started and ran no problem, mechical fuel gauge worked, and had 3/4 tank, truck is 2002 ram 3500 24v h.o.
I've noticed over the summer the old airdog has been dying so I bought a new 95gpm fass pump.
completely removed the airdog fuel lines, wiring harness, mounts and everything needed for it.
Followed the instructions for the new fass install, I used a pre existing draw straw in the tank to pull fuel. installed the new fass pump, primed the system and hit the key to cycle the pump to push fuel into a bucket, ran about 3 gallons no problem, then hooked the the supply to the VP and opened valve for fuel gauge. Crack injector lines 1,3,4,5 then proceeded to crank the truck over till fuel came out, only got fuel lines 4 and 5. I then cracked 6 and still no catch anything. I closed all the lines then and tried to start and got nothing.
Also, codes are pcu 1693 and Ecu 0234 0230 0577 currently.
I tried hooking up the snap on scanner and it would read ABS but I couldn't connect at all to the ECM but after all this I'm at a loss, am I missing something here?
