2000 diesel torque converter
- Replies 38
- Views 8k
Close... Lockup occurs when the "release" pressure in front of the lockup piston is exhausted via the hollow input shaft. When the converter is unlocked, it is being charged by the VB thro
You can't conclusively check for resistance in an active circuit. The current flowing in the circuit will cause all kinds of weirdness with your meter and its readings. Checking voltage on the ground
Be sure that the orange/black wire at pin #C2-11 on the PCM is not shorting to ground or the torque convertor clutch solenoid is hanging up. .
ok unlike most My converter does not unlock most of the time. I have replaced and checked new alt. with new method, replace control solenoids, when I come to a stop it stays locked ,shifting to neutral does not unlock it. when I put back in gear will kill engine. when I restart it is unlocked. all though when I started it today after sitting all nite it was locked, shout it off when restarted it was unlocked.it seems to work fine when cold after warm up it fails to unlock. most of the time.also it was rebuilt about 10000 miles ago with new half billet converter.truck has 220000 miles
