Valve Cover Gasket Leak
- Replies 50
- Views 14.5k
JDHudsn 19 posts
Dieselfuture 10 posts
trreed 8 posts
jlbayes 6 posts
DF!!!! This sentence made my day!!! I lost a whole cup of coffee! (most on the monitor, some in the lap...) This is past the 6 degrees of separation... so were you the friend? did y
That may have been part of your issue. You should have torqued the studs right to 125. At any rate...head has to come off.
I kind of does look like busted gear case, better make sure it's not before removing head. That's kinda where kdp is in that area. Some one I know just bought a truck that had a crack in case and it w
Hey guys I have a road trip planned tonight. Any help would be greatly appreciated.
Long story short I was driving home pulled into the driveway noticed that I was leaking oil it is all over the side of my truck underneath the hood and all over the engine bay. I turned on the truck back on with the hood open to see where the leak was coming from and it looked like it was coming out of the valve cover gasket. Have you guys ever lost a gallon or so of oil from this gasket in less than a 1/4 mile? Or do I have a bigger problem?
I have attached a picture below for reference
The video might help. Btw the sound is totally new with this issue
A0184BA3-8D0E-41CE-BC2F-8E8D420976B6.MOV
