200 Degree Thermostat... POSSIBLE?
- Replies 17
- Views 7.9k
Mopar1973Man 6 posts
kzimmer 4 posts
pepsi71ocean 3 posts
TFaoro 1 post
Popular Days
Even if you want to swap back to a 190 it is easy to do with only the loss of a cup or so of coolant. Just take the housing off and fold the radiator hose back. Takes 5 minutes to do.
No. Yes. 24V will change timing based on IAT temperature so if you can get it to rise slightly the timing wil retard a bit and MPG's will climb.
Running around up here in -10 to -20 F weather I was seeing hot temps out of my vents with the 200F tstat. I find it cycles in the 197 to 202 range (after first open). IIRC the vent on max ac was push
Is there a 200 degree thermostat that I can put in my 2001 24 Valve? Can you post the link to one, or a part number?
The region I'm in sees temps averaging between -15 to 0 degrees Fahrenheit.
Opinions are always welcome!
