Dash Frame Core Mount Deck Assembly
- Replies 40
- Views 28.5k
Greenlee 11 posts
dripley 8 posts
Blueox01 3 posts
Sycostang67 3 posts
Damn what does that thing weigh. It looks like Dash-O-Zilla.
I saw on YouTube where a fleece backing was used by gluing it down and fiberglass resin brushed on after it dried. I don't see where chopped fiberglass wouldn't work in place of fleece cloth. Yours mi
Replaced my interior/ dash with a junk yard dash, from a u-pull-it yard, I had the light gray interior but the dash was broken where the A/C controls mounted, was going to try and fix, but it was to
This is a topic I also posted on the Cummins Forum because I have seen a lot of Dodge folks with the same issue I have. This is what I wrote:
This is just a heads up for those folks like me who have the inner dash fame core mount deck assembly broken. I have been trying for several months to locate one and found some on eBay but a complete unit may run from $550.00 to $800.00 depending on the salvage yard that is selling it. Getting pieces from one that might be broke or ruined when removing it doesn't fly either. I have offered to pay a good amount for the broke pieces I need to glue back. With all the glues out there now that work excellent on plastic to plastic or alum or to carbon fiber it would be worth the while to give it a try. It's better than looking at your head light switch hanging or the A/C protruding outward from the top support piece missing and so on. But bottom line is the item is called by the title of this thread. Hope this will help some looking or have had their trucks broken into and the dash tore up in the process. I have some pictures of the complete assembly for a 1998 Dodge Trucks attached. I haven't posted pictures before but they are listed below under Attach Files. Hope you all have a Blessed and Prosperous New Year.
These photos might help if you are trying to rebuild your core and need to know what the original shape of it was.
