- Replies 15
- Views 4.9k
015point9 4 posts
Mopar1973Man 3 posts
JAG1 2 posts
Dieselfuture 2 posts
Popular Days
I agree... WD40 is junk. I tend to get two types of PB Blaster. The standard PB Blaster for getting frozen fasteners apart. As for typically lube maintenance of the vehicle I like the PB Blaster silic
Place a floor jack under the door with a block of pine wood between them. The jack will support the door and the soft pine wood will not mar the bottom of the door. I've done this many times on car
Have used a motorcycle/quad jack also ..... Used some bushings for a GMC .... they were a little larger and fit the worn holes better.
Drivers side door sounds like creaky old wooden porch. I've changed a couple over the years on different cars. 2nd gens have big door. I see "doorman" brand has them. Not overly impressed with "doorman" quality, but don't know of better quality brand.
Anything I should be aware of?
