2000 to 2002 Steering upgrade
Hello guys I'm not sure if this has been discussed on this forum before or not. I am considering a steering upgrade for my 2000 Ram 2500. This thread is too help anyone out if they ever want to try this to. Id like to know if anyone else here has done this specific kit ill mention? The kit is from a 4th gen truck and was made specificly for upgrading third gens steering. SOmeone on Cummins Forum bought this kit for a second gen and found out that it was a awesome bolt on upgrade for second gen trucks to! Now I read that trucks with stock 16 inch wheels the stud on the end of the tie rods will hit the wheel so you have to grind off an eighth of an inch or so. I don't believe this works for 98 and 99 trucks but correct me if I'm wrong. Anyways the part # for the kit is #51122362af and that's a mopar part number. Hopefully I can try this upgrade soon but in the meantime id like to find out more about it and possibly create an article when I'm done to help others. I think you can get this kit straight from the dealer for around 350$ which is a very fair price if the upgrade is as good as mentioned. Everyone knows that our steering kind of sucks. I think that big tires and leveling kits make it worse too. This converts the steering to a t style instead of the factory y style steering.
Edited by Marcus2000monster
  • Replies 176
  • Views 30.9k
  • I worked in a Western Auto for my first job at the tender age of 14. Never touched any over sized wheels and tires back in 1967. To young to operate the tire changer. But Loyd the boss man helped moun
    What made it bad is I've already got a bad back. Little cars not a problem I could throw those all day. Fat Ford with 37-inch tires I typically past the job up to the Shop Pup's so I didn't trash my b
    Be careful custom sizes might increase prices fast. Another reason I hung to the 235's they are really common out here and really CHEAP compared to 17's yet. Like my set I'm running now of the Hankook
M,
Yes this is true with engine oil, BUT we change it MUCH earlier.  The oil dies from combustion byproducts, not "viscosity breakdown".  It gets "dirty".  Rarely was there a combustion engine (for standard motor vehicles) that had oil temperature problems that were more damaging to the oil faster than the dirt build up.  (you could think early air cooled VW flat 4's, some air cooled motorcycles. Some of the newer small turbo or supercharged 4 cylinders may have a tendency to overheat oil.. turbos especially can do that.)   You can watch here on the site, there are some guys that have their oil tested to make sure the additives are still there and such and only change it when it is finally "too bad" to repair.
I am responsible for some 500 hp gearboxes at work.  These gear boxes have never had an "oil change" in 30 years (they hold 200 gallons).  but we send off samples quarterly, and based on recommendations, add additive packages into the system, or sometimes remove 30 gallons and add 30 of new.  But the heating/cooling system keeps the oil at a constant temperature.  Water is one of my biggest problems and am constantly running a portion of the oil through a water separator.
Hag
12 hours ago, Mopar1973Man said:
Now add the wheel no one runs just a tire without a wheel. I always measure fully mounted and aired tires on the scale.
On ‎2‎/‎14‎/‎2018 at 5:02 PM, Mopar1973Man said:
Not to mention if you have a filter and in plugs up are you willing to lose steering and braking control because you trying to extend a fluid change interval? Not I... I'd rather change it every 30k miles.
A quality transmission/power steering filter has a bypass valve in it, like an oil filter does, other wise there would be a lot of burned up transmissions out there.  So as far as losing your steering or brakes because of it, I don't think so.
An inline filter does just that, it filters the fluid of different particulates.  It does this two ways.  First the fluid passes over a magnet which collects any iron particles.  The fluid then passes through a filter which removes the other contaminants.  The filter will in no way protect the fluid from thermal breakdown but will protect the pump, steering box and hydro boost from premature wear and brake down due to contaminated fluid.
Wrong thread?
8 hours ago, Marcus2000monster said:
Wrong thread?
Maybe he meant to say that when people put bigger tires on, a lot of times they put aftermarket rims on too, which are heavier so total weight will contribute to even faster degradation of power steering fluid and wear and tear on the gearbox and other parts.
 I'm just making things up as I go trying to read between the lines.
Work in a tire shop for one summer you'll understand the weight difference really fast everytime you lift those heavy 35 and 37-inch wheel and tire combos. I've worked in a tire shop twice in my life so far.
I worked in a Western Auto for my first job at the tender age of 14. Never touched any over sized wheels and tires back in 1967. To young to operate the tire changer. But Loyd the boss man helped mount the 4 tires and showed me how to mount the right side tires and then left me alone to mount the left side tires. Does any body remember that left side Chrysler wheels had left hand threads back then? I sure did not. Could not get them started. Lefty loosy and righty tighty is all I knew then. Loyd loved every minute of it.
Lol I actually have for short time, but when I really felt some waight is when I built my own 20" rims out of military split rims, took 2 to make one and some custom cut centers. Just the rim weighed about 90lb and tire was about 380lb I put them together and on my truck all by myself,  it was fun least to say. I manhandled all of it, but I was young then. When I went to get my tires guy couldn't belive that I loaded them all buy my self, he had bad back and said I was crazy, I know now why as I got a bad back now lol, I'll never learn probably die before I do.
Hehe I get it now...
I can just see ol Mike draggin tires around all day! LOL!!
HAHA!
What made it bad is I've already got a bad back. Little cars not a problem I could throw those all day. Fat Ford with 37-inch tires I typically past the job up to the Shop Pup's so I didn't trash my back attempting to lift those heavy bastards. All I had to do is even do a rotation on a truck with 37's and I was hurting for the afternoon. I really do understand the weight differtence.
Yes, I do my old 1972 Dodge Power wagon had those too.
Back in the days of my first digital camera that was a 0.3 Megapixel. LOL...
This is the truck I ruined the front axle on with oversized tires. Done enough damage that I needed to get rid of it. So it was a trade in for my 2002 Dodge I've got now.
HAha!
9 hours ago, Marcus2000monster said:
HAha!
You can just use smily that's laughing in original post to say ha ha, just saying. Don't take it the wrong way. :cheers:
Edit; and now I realize that you did ha ha. My bad. You :spank:me
Edited by Dieselfuture
:hug::lol3:
Whats the most likely cause of my truck pulling hard to the left? I get really tired of fighting the wheel lol.
Just now, Mopar1973Man said:
Most likely a wheel alignment problem. Is there any strange tire wheel on the front tires?
All 4 tires are identical. I'm thinking its linkage but everything feels tight.
Calipers ride on slide pins. I'm guessing your caliper is hanging up on the slide pin.
