Who here is running a Fass Titanium and did a clean, nice install running your hose etc etc ?
Got some question.
I have a long bed. First question: Did you mount yours it at the most forward bed bolt bracket on your long bed ? Short bed would be like the second bracket back on a long bed.
I called a Fass few times and asked some questions about their parts and install already.
Post your pictures if ya got any
Edited by GSP7
  • Replies 14
  • Views 3.1k
  • If you’re worried about the 90s restricting flow you could always get other fittings from Vulcan or somethin. I have one 90 on my long bed. I think it just made the most sense to use it due to how I w
  • Dieselfuture
    Dieselfuture
    Wow nice and clean  ^^^^ I would definitely not be scared of setting my sandwich inside that fender working on that fass
  • So you don’t like the setup or the size?    Ive had zero issues with road debri and can’t speak much on gelling as I’m not in as cold a climate.    Either way, mounted in that gene
Long Bed. Forward most bed mount. Used draw straw 1 in factory module. All fuel line covered with convoluted tubing (wire loom) and zip tied to wiring harness that runs along the frame.
Gipper,  I see you didnt run their 90 degree fitting on the pump at suction port. That was one of my concerns
If you’re worried about the 90s restricting flow you could always get other fittings from Vulcan or somethin. I have one 90 on my long bed. I think it just made the most sense to use it due to how I wanted to run my hosing but it’s been a while now since I’ve done it. Either way you’ll be fine.
Wow nice and clean :thumb1: ^^^^
Edited by Dieselfuture
Took me a minute to figure how you have that mounted. On the second bed bracket back and pump attached going forward toward the cab. Good Idea. Good photo angle, Looks Good
Got any other pics of how your other hoses are run? I dont see the return line
Edited by GSP7
Thanks bud, that was on a clean install though so everything looks extra clean haha!
Sure I’ll take some from the front to show the return. Give me a day or two but mainly I just wanted to route the hoses up and over the frame as soon as possible so they’d be left exaposed as little as possible to anything that could get stuck up in there.
Really don't like those setups.
I installed a FASS 150 for local gent right here in New Meadows, ID on a 2000 Dodge Ram 2500. To this day that truck still has problems with gelling fuel and road debris hitting the FASS filters because its installed just like seen here. So after a few miles of snow cover highways the filter are buried in packed snow and ice.The other problem is that FASS are so big in physical size they are very difficult to hide on the truck away from a damage path or thrown snow and ice.
Remember FASS and AirDog is a Son and Father setup. Where the son owns FASS and father owns AirDog. Same family different ideas.
Image result for compare air dog and fass
Either way, mounted in that general area, which both companies tell you to do, will expose them to just about the same amount of elements. Not everyone wants to install them where you did yours Mike. Putting a shield in front of the pump wouldn’t be difficult either if debri and cold was that big a concern.
Edited by notlimah
Once again, that is just "your opinion" and is a None Issue.
This is true.
And that picture of the size comparison is the older units not the smaller Titanium which isnt even pictured
Edited by GSP7
I just installed a FASS 150 last year. Trust me the FASS 100 and FASS 150 are still that big. They haven't got any smaller. Also, you are right the Titanium is not pictured. Yes, the filters hang way down in the blowing cold and damage path.
Back years ago people got smart and mounting FASS and AirDog both in better places. I've seen several good installs where people tucked FASS in the void of the rear box which gave it really good protection from the blowing cold and small piece of metal or plastic to extend the fender on the front side.
Now people just don't care just bolt it on and consider it good till problems occur. Like my example of that truck in New Meadows, ID with the gelling problem every winter. I admit I hung it the only way I could because the truck has a flatbed and utility box on the driver side. Still in all the filters are in the damage path and hanging in the blowing cold and still gell up every winter where I've never gelled up even once yet.
Then again I've seen rancher with FASS hung in the typical location and tear up filters because the hung below the level of the frame. Just be going over a water bar and sink into the mud and swipe off the filters hanging down. Little steel box won't do much with 8,000-pound truck smashing the filter into the ground. I've seen even Raptor's that taken a good beating from a tree llimb that was driven over and whipped up and trashed the pump.
So its not exactly a non-issue. Location and mounting does play a huge role in if you are going to have issues with gelling or filter damage.
This is true.
Do you have a current picture of the titanium for comparison? I have always thought at least an inside frame rail mount was better that  an outside frame rail mount to get it further out of harm way. @notlimah not trying to beat you up you have a clean install. Just like the the inside frame rail mount better. Personal opinion thats all.
Here’s another pic. Sorry it took so long.
I get this isn’t the most ideal spot due to road debris, but I think it’s fine for anyone not doing the majority of driving off road. Otherwise I’d fab up a shield and call it a day.
