Injector ash
So i pulled my injectors when i installed valve springs and mantons...well they were dirty as heck and full of ash.could barely see the holes,truck has had optilube every tank since injectors went in (2 yrs ago).is this normal??thanks
  • Replies 25
  • Views 5.8k
  • So this is what ive been running and after the look of moparman injector with 2 stroke i will be discontinuing use What I don't get is it says keeps injectors clean but I have been running this
  • I have stayed around the 1 oz gallon but not to the point of being exact by any means. I also see several places where i buy fuel mixed with bio diesel. I usually dont run any 2 stroke if i am running
  • probably ought to change over to low ash 2 stroke oil.
what level on the smarty are you running?
Level #4 since jult 2017
I dont,im kicking myself in the butt for not taking pics
This is not normal.
Cetane booster tend to add soot to the injectors. 2 Cycle Oil you might try it. I'm going to bet my 80k miles injectors are cleaner that your 2 year injectors.
Yeah mine were definitely dirtier than that...how much 2cycle do i add to say 10 gal diesel?
I think Moparman does 10 ounces for 10 gallons. Me.... I usually guestimate pouring a full bottle of 2 stroke filling a 3/4 empty tank. Engine seems to thank me for doing that.
No. I pour approximately 1/2 quart for half hank a tank of fuel.
Suggested is 128:1 ratio of 1 ounce of oil for every 1 gallon of fuel.
Would there be any downside to putting in say 1.5 or 2 ounces per gallon?
What would that amount come to per gallon?
What I don't get is it says keeps injectors clean but I have been running this every tank exclusively at the higher treatment dose for two years since my new injectors went in and they were horrible with Ash build-up and carbon
I try to stay around 1 ounce per gallon, but  don't don't get technical about it. If I'm filling a half tank I pour in a half bottle that way it gets mixed as the tank is filling with fuel.
If its hot weather and I'm hauling heavy I might add a little more at times, but not much more.
I have stayed around the 1 oz gallon but not to the point of being exact by any means. I also see several places where i buy fuel mixed with bio diesel. I usually dont run any 2 stroke if i am running bio mix. Since below 5% mix does not have to be labeled I usually throw the 2 stroke i. If there is any doubt.
In the summer time I'll step over into Ontario, OR and get B5 diesel its about 20 cents more a gallon but it pays for not using any 2 cycle oil. During the winter time I been staying to strictly Idaho diesel which is good old petroleum based no bio. Biodiesel has a problem of separating out as it cools and the bio part sinks to the bottom and turns like old bacon fat in the bottom of the tank. There is no product that can handle the gelled biodiesel.
How do you now if the station your using is pumping bio fuel? Will it say on th epump?
Oregon is mandated to provide B5 biodiesel minimum. So all Oregon pumps typically show they are Biodiesel but as for the amount its unknown it could be up to 20% biodiesel.
Idaho is still a petroleum diesel state rare to fine Biodiesel stations in the state.
ANy idea about Montana? Guess I could ask at the station next fill...
At the moment anything 5% or less does not have to be labeled. Over 5% does. I see stickers on pumps out my way that say it my contain 5 to 20%. Wish they were required to do a better job of labeling. I have never had any of it gel but I also do not see as low a temps as y'all see out your way. My truck loves it, but I would still like to know to what percentage it is mixed.
 I built a Loves travel center a couple years ago and they have a separate ug tank for the bio and they mix it on site so control how much goes in.
  • 2 months later...
So i just pulled the injectors again 3 months later to upgrade...they were all full of carbon deposits again..been running 2 stroke since my original post in feb... so that tells me that it wasn't the optilube. Do you think it could be direct relation to the smarty?
