Did my VP go too?
Well I thought the truck was running good... It sat last night and most of today and I went to start her and she fired first crank but idle extremely erratic and had a nasty lope and unloaded a mass cloud of white smoke... New injectors went in a week and a half ago and all seemed well until the lift pump failed. I'm thinking the LP took the VP too. Fuel pressure went straight to 20 psi so that's not a issue. Ran the key trick and got P1693 and then -------- and then P Done. checked for codes and found nothing.
  • Replies 211
  • Views 38.1k
  • I would not do that.  If air intrusion is suspected the last thing you want to to is suck water and soap onto the fuel stream and send that to the IP and injectors.  Besides you will never see a singl
  • For now i would clean up the connection and make sure you seat it good to see if that's the problem. I know those quick disconnects have a bad rep but mine have been in use for 6 plus years and they a
  • Marcus2000monster
    Marcus2000monster
    Let’s say eating cuz I don’t have a friggen clue how to bake a pie! Hehe
9 hours ago, Marcus2000monster said:
Eric is awesome! He answered the phone on a SUNDAY and helped me figure it out! He has earned my bussiness for life! A fine man he is! :thumbup2:
Yes indeed
Well guys I get home this afternoon from Georgia. Draw Straw should be there ready to install!
Will a sump do the same as a Draw straw as far as eliminating the air leak that is entering the fuel line?
I would suggest the draw straw. I'm still using my 12 year old AirDog old school draw straw without issues. Matter of fact I rolled into the fuel station with a 1/8 of tank.
Well a sump is more simple then a drawstraw but there’s potential legalities with a sump.
Generally leaks are pretty simple. If you’ve narrowed it down to the leak being somewhere in the tank you could drop the tank and remove the fuel module and tighten everything up, or worst case, change out all the fittings.
But to answer your question, yes as long as the leak is actually in the fuel module.
Man idk what I should do. Dropping he tank and removing the bed is a pain in the A**!!!! I have the Draw straw dojo light as well put that in but gee it’s going to suck.... I was thinking about just getting a Beans sump so I wouldn’t have to drop the tank ilor raise the bed but heck I have a Draw straw on my bench. I’m sort of worried about 1/4 tanknissues tho. Hopefully the stRaw will solve my issues cuase I get madder by the day because the truck won’t run right! :doh:
If you are using your truck offroad at all I would steer clear of any sumps. If you hook that sump its game over for the fuel tank. Finding replacement fuel tanks are rather tough these days.
Still questioning if it’s a leak or Bad VP44. Hoping the straw will tell me....
Never been off road yet... I’m just going to tear into it and stuff that straw in there. Iv got a feeling it’s going to be a waste though.
Just put a draw straw in if you already have it, make sure you cut bottom like @Mopar1973Man and have it an 1/8 or so of bottom if tank is full. It will flex a little too. You can always put a cap on it if it doesn't work later and do something else.
Got the Fass unhooked and removed. Just got to take the rest of the bolts out tomorrow and install he Draw straw . Any tips or suggestion?
I cut my straw flat on the bottom with the thickness of a single quarter coin. I lightly notched the tip with an angle grinder. I did all my measurements on an EMPTY fuel tank this way as the fuel weight will bow the tank away from the straw tip. This way as the fuel tank empties it will pull the bottom up towards the tip of the straw.
Seriously considering putting my fuel system back to what it was with the exception of the big line kit from filter to bottom and a raptor or frrp. The truck ran so good with the old setup and now Iv got nothing but problems.
Did you ever determine whether that you did have air getting into the system? Neither way will stop air infiltration if it is getting in after the fuel tank.  I personally would not cut a hole in the bottom of my fuel tank.
We think we narrowed it down to air getting in at the top of the fuel basket. So I ordered the Draw Straw to fix that. Still don’t know for sure that it’s air though.
Couple more variables. First off the truck never starts hard! I have done a ton of research and looks like everyone with air leaks has hard start issues. Next right after I installed the Fass the 3rd time I started it with the new pump I got the crappy idle and a TON of white smoke. None of that smoke is there now. Just throwing that out there......... We’re going to get thus figured out and make her run good again!! Thanks
As for the sump idea... At any rate the seal or o-ring will fail eventually on that sump. Sure would suck later in life that sump seal is no longer manufactured. Then end up trying to patch a massive hole in the bottom of your fuel tank. I've already had two people down this road and fought to replace the fuel tank.
I done screwed that idea. Lol. Getting ready to go work on the truck again this morning. If the Draw Straw don’t fix it what should I look at next?
I'm not sure what kind of connection fittings you are using. I'm using strictly Parker push lock JIC fittings. If you got any kind of Quick Connect fitting that will be part of the problem. The newer AirDogs I known use Quick Connect Fittings and are know for the o-rings to roll back and start an air leak only while pumping. Talk to Eric at Vulcan Performace about this he can explain it.
THe only quick connectmis on top of the fuel basket soon to be eliminated.
My money is on this connection. I bet if you cut the fitting off and just hose clamped it temporarily it would solve the problem. Those fitting even back in the AirDog days in the early 2000's had issues.
We’re going to find out soon! :thumbup2:
