Hard start after grid heaters disconnect
So 2 days ago, I disconnected my grid heaters after testing ac noise. Which was .034 after using them all winter. Now the wait to start comes on like normal, I turn truck over it's barely stars and then dies.so I turn it over again,  get it to idle, and its puffying out white and blue smoke like a train from exhaust.
Temperature was 36 at 7am when I started it.
I disconnected grid heaters at battery like it was suggested so as to not throw codes.
I feel like I should just reconnect the grids back up, i haven't replaced a alternator yet since i have had the truck for 6years. When i use them truck fires up first crank with just a haze of blue till it warms up.
  • Replies 36
  • Views 7.2k
  • Tractorman
    Tractorman
    The only benefit to this method is that no codes will be set, but as you see, you don't get to use the grids when you want them or need them.    I chose to wire in a momentary switch and mou
  • Tractorman
    Tractorman
    I just realized that I gave the incorrect information in the above post. As of 7:25 pm I have corrected that post.  I should have said that I installed a switch that supplies 12 volts to the control r
  • My little truck had a grid heater delete and would do this when cold.    Summer/warmer weather there was no issue.    I plugged it in. Problem solved. I would take off when coolant
WTS light is based on two sensors. IAT sensor and Battery Temperature sensor. So if the temperature is below about 60-65*F it will trip a single element grid heater regardless of being hooked up to the battery or not. So the WTS light should reflect the normal grid heater operation but you won't see the heavy voltage drop.
I just reconnected the grid heaters. It's just a night and day difference for starting. Smokes like a locomotive when not connected for about 30 seconds, barely a haze when when it is connected.
On 4/13/2018 at 6:05 PM, Dieselfuture said:
Could you remind me again if you spliced in ground wires for relays triggers or disconnected them on the body somewhere
Just food for thought. Tractorman switched the + relay triggers wires while I switched the -. Relay needs ground and hot to work. I chose to switch the grounds therefore leaving everything hooked up the way it is OEM except for the switch. And the switch is spliced in between.
Edited by dave110
Here's an idea.  If you want to fool the computer (like Mopar1973man likes to do - you know, the IAT fooler), you could measure the resistance of each intake manifold heater coil and then wire in a resistor of that value from each trigger wire to ground.  That might stop a code from being set.
For me, I don't mind the set codes.
- John
Either I missed the answer to my question order has never been answered fully. If I put a toggle switch to toggle negative side of trigger wires for relays, do I splice in somewhere near the relays or do I follow small ground wires to a body someplace and toggle at that terminal, which is what I kind of want to do instead of splicing wires.
 I cut the wires leaving the special nice connector on the relay studs, butt connector and shrink tubed a wire of the same size to it, ran the wire to a toggle inside the cab, and back out to the other end of the wire that I cut and butt connector with shrink tube to it. I don't know if the original grounds ground through an ECM ground or if they are grounded to an external ground screw. Wire schematic might show that but for me it was easier to splice than to chase that down. After all, 89% of us are running around with the VP44 pump wire spliced in one way shape or form. Even the stealth cover needs a wire with a ring terminal spliced to it.:2cents:
- John
Or run a second set of $75 relays between the battery and the original leads. Make that the 'manual' set that you control. The ECM would still see the OEM set and think it was in control of them and be happy. If the codes bothered me I would rather go that route for simplicity but the codes mean squat to me. I know they are there and what they mean.
Wouldn’t it work to put a toggle actuated solenoid between battery and relays. I’m kinda electrically challenged but was curious if this would work.
Yep. Same theory. I considered this but the cost of a solenoid that size gets kind of pricey. Plus to do it right you should have 2 , 1 for each relay.  There's 2 grids. When I saw the $75 E-Bay relays it just seemed like a better route to go.
The question has been answered.  Whether you toggle the positive side or the negative side of the relays, you do not have to splice into any existing wires.  In your case, disconnect the wire on the negative post of each relay and protect the wires from the elements as they will no longer be used.  Then make a new wire (18 gauge is fine) that connects to both relay negative posts and run the new wire into the cab to  your switch and then to a ground.
If you use  a maintained switch, when it is switched off (open), the grid heaters will never operate and two codes will be set.  When it is switched on (closed), the grid heaters will operate normally.
I chose to toggle the positive side of the relays with a momentary switch because I wanted to be the boss.  I can choose when and how long to run the grid heaters.  I think there is something in the Constitution about this freedom.
I can also load test each battery independently by turning on the grid heaters for 15 seconds at a time and monitoring battery voltage during the test.  Nothing like a built-in tool.
- John
Edited by Tractorman
content
Only thing I don't like about that is if you're forgetful like me and leave the switch on.............well you get the idea. That's why I spliced into mine. When I turn them off they are off no matter what, but when they are on the ECM  will operate them normally and turn them off when I forget. My forgetter is getting better :whistle2:.
Come to think of it I think you said you use a momentary switch would will also protect you in the event you forget.
Haaaa, it's so easy I was in full retard mode trying to find where relay trigger grounds went. And all I need is ground a heavy wire that can support both relays coils then got to switch then to relays. Thanks for clarification @Tractorman once again. I tend to over think a lot and give myself a headache.
You are getting closer.  You do not need a heavy wire.  Each relay consists of an internal coil and a switch.  When the coil is energized it operates the switch.  The coil only draws about one-sixth of an amp or about 150 milliamps, so light gauge wire is fine.  The internal switch handles the load - about 100 amps for each grid heater.  You are not tapping into the switch part, so no need for heavy wire.
Note the wire sizes in the wiring diagram for the relay coils (18 gauge).  Note the wire sizes for the relay switches (6 gauge).  Also, the wires that leave the bottom of the page go to ground - not enough room to show it.
Please let me know if I can make this more confusing.
- John
more info
  • 4 months later...
Didnt want to start a new thread, but I do have a question in regard to the grid heater. Soon the cold will be back and I don't have the ability to plug my truck in where I live. There are 2 grid heaters right? Can i just have one turned on? Less load on the alternator right?
I don't see why not, just unplug one of the relays trigger wires, but I think one of them is higher amps then the other. You'll still have a code set.
