Hard start after grid heaters disconnect
- Replies 36
- Views 7k
Alexio Auditore 7 posts
dripley 5 posts
Tractorman 5 posts
dave110 4 posts
The only benefit to this method is that no codes will be set, but as you see, you don't get to use the grids when you want them or need them. I chose to wire in a momentary switch and mou
I just realized that I gave the incorrect information in the above post. As of 7:25 pm I have corrected that post. I should have said that I installed a switch that supplies 12 volts to the control r
My little truck had a grid heater delete and would do this when cold. Summer/warmer weather there was no issue. I plugged it in. Problem solved. I would take off when coolant
So 2 days ago, I disconnected my grid heaters after testing ac noise. Which was .034 after using them all winter. Now the wait to start comes on like normal, I turn truck over it's barely stars and then dies.so I turn it over again, get it to idle, and its puffying out white and blue smoke like a train from exhaust.
Temperature was 36 at 7am when I started it.
I disconnected grid heaters at battery like it was suggested so as to not throw codes.
I feel like I should just reconnect the grids back up, i haven't replaced a alternator yet since i have had the truck for 6years. When i use them truck fires up first crank with just a haze of blue till it warms up.
