Muffler or resonator delete
Going to head to a local muffler shop tomorrow to get either the muffler or resonator taken off my stock system. I assume it would be a better idea to delete the muffler and keep the resonator. I would appreciate some input on which to do and has anyone done this. I just want to get a little more sound out of my truck but not have too much in cab drone. A friend did both and the sound is nice. But the best part is the cost. They only charged him 80 bucks to do both plus a chrome tip.  Can't even get a muffler delete pipe online for that price.
Thanks in advance.
L8tr
D
  • Replies 56
  • Views 18.5k
  • Sycostang67
    Sycostang67
    If it's too loud, you're not old enough.....to have lost enough of your hearing so that it doesn't bother you.
  • Royal Squire
    Royal Squire
    I was visualizing something much more complicated!  I guess that’s what you call a “tuned” exhaust system
  • Tom Robarts
    Tom Robarts
    The wide lap joint clamps are far superior to the steel rod type clamps, if needed with the lap clamp you can still get the exhaust apart
IMO....you guys are way over anylizing/building a better mouse trap type stuff.
Big truck places already have this made.
Thats 4” exhaust. It is specifically called exhaust heat shield.
That being said I have never seen any ill effects tranny temp wise from the exhaust being right there.
Even with 5”.
Side note.  @KATOOM
I was rooting through some DTR and realized you and I along with some others have been in this goat show for a while.
Those were fun days.
1 hour ago, Ben said:
Side note.  @KATOOM
The first Cummins/diesel forum I joined was back around 2001-2002.  Back when I had dial-up... :duh:
5 hours ago, KATOOM said:
Nice...  Did it do anything?
Below 50% load sounds real good. I can actually here the nice tone of the exhaust.  Above 50% still some drone but not quite as much.  Man these straight sixes sound soooooooooooooo much better than those V8 diesels.  :cummins: :stirthepot:
L8tr
D
L8tr
D
That's been a given for over the last 25 years Clark.
:iagree:
My fault. I missed the dealing with the drone part. I thought the fence posts were being used as heat shields.
That actually is a good idea.
I guess I have been lucky with drone on my trucks. I just got the 4" Diamond Eye stainless on 2 weeks ago on the new one and all is well.
Is your 4" Diamond Eye Stainless a straight thru system with no muffler or does it have a muffler/resonator?
I plan on going with flopro when I get an exhaust. They extend their welds to wrap around the pipe more to cut down on fatigue over time and I think also reduce vibration. They also come with the nice band clamps already instead of the crush style clamps most others come with.
I would love to hear back on this whenever you do...  VERY curious to get some accurate and unbiased feedback on either the FTE of Flo Pro. :thumbup2:
Edited by KATOOM
I would love to hear back too.  Feedback on any systems/muffler & resonators for that matter.
FTE resonator eliminated drone on my 5" exhaust. With resonator and muffler, the exhaust is quieter than the engine
I can confirm the FTE takes away the harsher raspy idle and cuts down on idle noise on a diamond eye 4in for sure. Haven’t ridden in the truck but what I’ve been told is no drone and a lot quieter but still sounds good.
I guess its worth saying that the only reason I'm even considering a resonator would be merely to eliminate any drone...not to quiet the trucks overall exhaust note.  Thank you for the feedback too. :thumbup2:
Sounds good. Whenever I get a new exhaust it’ll be flopro with 30in FTE so I’ll report back on what it sounds like.
Edited by notlimah
There's a muffler.
