- Replies 19
- Views 3.4k
Killer223 6 posts
Mopar1973Man 3 posts
trreed 3 posts
dripley 2 posts
well here are a few. the spot on the passenger side was a small crack., well a 5GPM 4500 psi pressure washer and unatentative operator made a mess of that. bumper is a little crooked, all doors
The 3000K springs mean it has 3000 RPM governor springs in the pump. The #8 fuel plate controls fueling, and has a more aggressive fueling curve than stock.
Sweet! Nice rig!
SO i found a 12valve long box 5 speed 4x4.
it's not in horrible shape. but it also has 306K on it. trans looks new. P pump is new, new injectors.
could use some control arm bushing, steering will move from 10-2 and still go in a straight line. no major oil leaks. no blow by that i could tell. shifted amazing compared to my G56. has no rust, rear air bags. AC works. forgot to check heat as it was only 88 outside.
this is a joy ride truck, toy. wood cutting truck. he's asking 8K i offered 5 and he said no. so... how much would someone say it's worth. ball park.
it''s my second unicorn truck, 12V 5 speed long box 4x4.
thoughts.
