Suspension measurements needed
- Replies 23
- Views 4.2k
PilotHouse2500 8 posts
dripley 5 posts
BBHD 3 posts
notlimah 2 posts
Here's what I have. Upper control arm passanger side. This is to the center of bolt 14 1/2" 12 1/8" On the steering knuckle 16 1/8" to the underside of the casting the tie r
If I can get on some level ground I'll get some measurements for you.
Here’s what I have, this is with 285/75/16 tires and an auto tranny, and stock suspension. If your looking for the upper control arm measurements 22 1:8 20 1/8 these are from floo
OK guys need a little help here. Was looking at the body tongiht and getting it lined up when we thought about not having all the all weight on the frame will shift the suspension a bit relative to the frame due to the linkage pivot points. This would explain why some things didn't line up as expected. So I am looking for the following measurements from someone with either a 2500 or 3500 frame/suspension set up (6bt engine and manual tranny if possible!). Please note back where the measurement was taken from to the ground (center of bolt, top/bottom of bolt, joint between members, etc) something I can use as a solid reference. I plan on torching the springs to get it to sit where it should (putting bags in instead on the build). Thanks in advance!
Note where the fingers are (should be 4 measurements). 2 pivot bolts on the arm, the pivot on the pitman and the pivot at the passenger wheel
Edited by PilotHouse2500
