- Replies 20
- Views 3.7k
Me78569 7 posts
mistydawn04 7 posts
dripley 3 posts
Mopar1973Man 2 posts
Popular Days
11 psi at idle isn't the worst thing ever, sounds like the vp was just worn out. You are feeling the effect of nearly 0* of timing. Guessing you are seeing white smoke as well? then the vp heats up
any vp44 from 1998.5-2002 will have a pump that works. Youhave a HO pump, but a SO pump will also work in a snap. The reason why it appears to work after the issue happens is the
I had that thought about every time I drove mine lolol
Hi Yall ive been working on my truck for weeks now and cant figure out whats wrong. when i take off in first gear it wont gobut 10 mph and the rpms go way up so i shift gears still to remain only 10-12 mph then it will all of a sudden start driving right this happens all the time and i cant haul my horses down the road comfortably knowing it might break down on me. at first it wouldnt start i kept trying to start it until i ruined the starter and had to replace that and one of the batteries then the fuel filter which was very bad i cleaned out bottom of canister also. air filter and replaced the in tank fuel pump also cleaned the banjo bolt in return fuel line it worked pretty good for a day or two but is back to its not going but 10 mph at take off sometimes what should i do next i had someone put gauge on fuel pressure it was 11 should i replace the throttle sensor? help
