2nd gen engine cooling
- Replies 42
- Views 16.7k
Mopar1973Man 11 posts
Akaiser21 9 posts
KATOOM 7 posts
AH64ID 7 posts
Ok guys so here is my update to my fix. With all the suggestions I have decided to try each one. I kept my toy hauler loaded full. 37' Toy hauler 100ga water full, XP1000 RZR, 2 dirt bikes and all the
What tires? did you regear? 3.73 is not a stock ratio. 3.54 or 4.10. what rpm are you towing at? I spend a lot of time towing over i70 and other passes like that as well. as long a
Drop your EGT's to about 1000-1100*F it will hang at about 205-208*F coolant. I got several steep grades here in Idaho and have no issues with cooling or engine temperature. Now if I was to push 1,200
Hey guys, just reaching out before I start spending some money. I have a 2nd gen dodge 5speed 3.73 gears with mild build. I recently bought a 37’ toy hauler that weighs close to 9,000lbs empty. I live in Colorado and when I tow this thing is usually over some pretty serious passes. As summer is here I’m struggling keeping my engine temps under control. I do have a high flow water pump, new oem replacement radiator and 190* thermostat. While pulling up RIO with my RZR in the trailer I got a little out of control on my temps. Probably 225*. My EGTs were getting a little hot at about 1250. My truck was getting hotter sooner with my antifreeze/water ration about 70/30. I took some advice from my father who ran heavy duty diesels for 20plus years and am running 25/75. As he said it will still get hot but not as quick. He was right. Anyone done anything to their truck to keep the temps down that actually worked while pulling heavy? I’m guessimg my truck and trailer combo was close to 24,000lbs when loaded.
