What is the "BEST" engine oil & filter to use and why?
I've seen a lot of info in this forum about engine oil but didn't run across any focused discussion on the topic.
If anyone knows of one please direct me to it, if there isn't one now would be a good time for one.
I'm planning to change my oil in the next few days.  My local parts shop recommended Delo 400 15w40 oil and WIX XP filter (see picture)
The fella at the parts shop also said something about using a thinner viscosity in winter.  I do go to where it's cold but it's not exactly cold in Los Angeles.  I'm hoping some of you that live in cold climates will know about this first hand.
Let me know if this is the oil and filter I purchase are suitable and/or if there is a better option.  Everything is returnable :-)
Also is there some procedural steps that would be good to follow outside of the the common steps - Does this drain plug need a new washer seal etc?
1) pull drain plug
2) change filter
3) reinstall drain plug
4) refill 12 qts/3 gals of oil
Edited by leety
  • Replies 86
  • Views 18.4k
  • Ya'll are just bunch oil smearing, sandle wearing, coffe drinking north westerners. You even have a closet potato farmer in your midst. But you sure seem happy.    Imma gonna do a little sit
  • That is a pretty accurate statement. There is more than one product out there that will accomplish goals.  And just make every one cringe, I ran Fram oil filters and a K&N air filter for many
  • I dont trust those quick release drain valves   what if you drive over some sage brush and it flips the lever
20 minutes ago, Mopar1973Man said:
:lol2:Another way I look at oil and filters. Look at your big over the road trucks and what they run and the trucks go for long distances without failures. If it works for the bigger Cummins series engines there is no reason it won't work for the smaller ISB engines.
It does make a difference if you are doing longer distances ..... when your engine, transmission, transfer case, differentials are going through multiple heat cycles. Condensation is steamed away, everything is up to temperature, and things are being lubed the way they were meant to be. Dusty atmosphere is the only 'fly in the jam' .....
It makes a huge difference.
One must also consider the sump size vs engine size is anemic in this truck, and the smallest of any ISB. That means shorter oil life and higher oil temperatures.
Engine load cycles are also big, and more constant in heavy trucks. Look at the marine QSB getting 480 hp, and nothing in the road/truck market is close.
One can also look at the average fuel use vs displacement, big OTR engines actually lead an easier life.
If I am doing 65 mph at 20K lbs I get ±10 on the flat ground with 5.9L. A 80K lb OTR truck might be getting ±5.5 mph. So just under 2x the burn rate at 4x the weight, and 2.5x the displacement. It's a much easier life for a 15L.
When I fire up I'm running 6 hours. I travel 250 to 300 mile in a day for the last nearly 2 years. Even in the past my average distance per run day was at least 100 miles.
Delo 15-40 and Napa gold here. Change between 5-7K miles depending on how hard its been ran.
Actually most current  ISX15, X15, and other common engines in OTR trucking are getting closer to 7.5 - 8 mpg now days and even 10 mpg is not uncommon with a good driver that doesn't think he has to be first up the hill. Typical oil capacity is 44 - 52 qts. Typical spec'd oil change interval is 45,000 to 50,000 miles, even with EGR and DPF. Their typical cruising rpm is around 1400 rpm with a max rpm of around 1800 when rowing through the gears. Common power setting is around 450 horse 1750 torque, although they are capable of making much more. Most newer OTR trucks are being geared at 3.00:1 gearing or higher and seems direct drive autoshift transmissions are becoming more and more common.
The Chrysler ISB oil pan is about a gallon shy of what you would find in something like a box truck. Most medium duty 6BT and ISB engines used in commercial applications hold 16 qts. instead of our 12.
Cenex Superlube TMS for oil. Just because there is A LOT of it that flows through the shop.No sense in disrupting the cart.Cases upon cases of Cenex lubes show are delivered to the shop.
https://www.cenex.com/lubricants/commercial-fleet/oils/superlube-tms
Fleetguard Stratopore for oil filter.
For socks...Duluth Trading Company or Gold Toes.
Edited by Ben
