- Replies 95
- Views 18.4k
cumminsVP2001 36 posts
dripley 15 posts
Mopar1973Man 11 posts
snoogett 11 posts
Blue Chip Diesel has the write up on trouble shooting the vp 44. https://www.bluechipdiesel.com/troubleshooting-1
yes yes i know.
The problem is the tank is produced with two types of plastics the white inside skin than the black outer skin. I still have my doubt on plastic welding a fuel tank being I use to do the same kind of
hey all. i dont usually have any question on working on these engines, but today im a little puzzled. i changed the stock lift pump on my 2001 with a raptor 100. i had this lift pump on my other 2001, but i just got that one an air dog 150.
anyhow, ive changed lift pumps/filters on these trucks 20+ times and have done the bleeding procedure as anyone would. crack lines 1,3,4 bump a couple times till you get some fuel, crank until air is gone and fuel is clear, close lines, start.
today after i got done finishing my lift pump install i did just as i stated and i was getting some fuel/air from all three. line 4 started to get good fuel and it was acting like it wanted to start. all the sudden lines 2 and 3 went from fuel/air bubbles to nothing. i cracked the vp44 line and was getting good fuel there. i then started to crank again and again with fuel only coming out of line 4 and not 1 or 3. i then opened line 5 and got good fuel from 4 and 5 still but none from 1 and 3. it isnt even trying to act like it wants to start. no engine codes. im guessing vp is toast. whats your thoughts.
