Derale 15870 Install Under 3rd Gen
- Replies 12
- Views 7.4k
Dynamic 4 posts
Mopar1973Man 3 posts
notlimah 2 posts
Rogan 1 post
Yeah, I'm not a big fan of removing the heat exchanger, but I do understand why people do it. The stock cooling system on the 3rd Gen does have its weaknesses, hence my thermostat delete kit, but I do
On 2G trucks, I tend to mount them behind the front bumper on the left side, tucked up by the outer bracket; tends to work well there. Very nice job on the 3G, @Dynamic
NO, if you put the fans on a thermostatic switch, you'll be just fine.
Here are some pictures of a Derale 15870 cooler that I installed for a customer. I haven't installed any of the wiring in these photos, but the fan will be controlled by a relay. The temp switch is on the inlet side of the cooler, and will turn the fan on at 180 degrees, and back off at 165 degrees.
Here is the cooler (which is massive) and the bracket that I built to mount it to the frame.
And the bracket mounted to the frame...
The cooler mounted to the bracket. By mounting it at an angle, I was able to tuck it up against the bottom of the cab nicely, but not have anything hanging below the frame rail.
Another view...
And its associated plumbing. I used -8AN fittings and line throughout.
