- Replies 11
- Views 3.1k
Mopar1973Man 3 posts
Dieselfuture 2 posts
015point9 2 posts
Towrigdually 1 post
Popular Days
The ones with the yellow pull tabs. The fuse will pull from the socket but not fall out. The system is now disconnected. Like the IOD fuse and I think maybe 1 or 2 more in the panel.
I don't think it matters on fuel if you fill it all the way or empty that much as long as you don't use biodiesel, biodiesel has some moisture in it and if you're going to store it it could cause dama
If you seen all the fire truck that we have that are diesel just stuff in a barely heated shed. They sit for long periods without being touched. Then they are fired up and driven hard to a fire. I ser
So work just let me know i need to go overseas for a job. I might be gone for 3 weeks or up to 15 months. what have you guys done to keep these trucks to maintain them in storage.
already plan on unplugging the batteries and putting them on a battery tender, putting it on jacks to attempt to save the tires since they are only 4 months old now.
Figured put some desiccant and rat poison in the cab also.
what do you recommend for the fuel, Fill it all the way up or run till almost empty?
