I have a 99 cummins and it started to cut out at high rpms I though maybe it was the lp wo I did a volt test and it was putting out 13.1 volts checked the fp ar idle its sitting at 15psi changed fuel filter then added lucas additive. Yesturday my radio quit working but still has lights on it no dome light and no power to the diagnostics port if checked all the fuses they are all good. I have been told it could be a bad diode in the alt putting out ac noise and iv also been told bad ecm. I do have an issue with with my positive cables on batteries always getting super corroded not long after I clean them. I need some help here before I go dump a pile of money in this thing.
  • Replies 62
  • Views 6.4k
  • Rigtruck92
    Rigtruck92
    Sure lol its 800 to ship it to you I take paypal ??
  • There a rail of electrical connections with I think 3 cables bolted to it below the drivers side battery.  My truck was doing all kinds of funky stuff. Not starting, slow crank, shut off while ru
    Be careful there... ECM software there is roughly 53 different versions of software out there. Don't randomly just buy an ECM. Then there is change up like cam and crank sensors to just cam sensor (wh
I have a quadzilla I had just bought before these issues had started should I hold off on I stalling it until I fix these issues I dont want to fry the quad.
I dont think I would install yet.  Get the truck running right and then install.
If you want to I can put on mine and make sure it works.:whistle:
Edited by dripley
Ok so I checked the iod fuse it was blown changed it and I have dome lights radios back on but I'm still not sure about power to the obdll port. I cleaned the hell out of my batterys they were so corroded when I went to listen them up both the positive terminal clamps broke I'll be getting a whole new set of battery cables. But my truck fired right up and when I bumped the key the lp stayed on like it should. I still dont have a wts light but i ran a test on the cluster and it still didn't come on thinking maybe a burnt bulb. Gona see how it runs tommoro
OMG... :doh:
Dave you just going to have to toss that Edge Comp in the pile for sale and buy a Quadzilla...
OMG... :doh:
Later this year I hope.
Good to hear. Work your way thru it before buying parts, especially expensive ones.
So this morning my wait to start light has came on everytime but its delayed. I think I'll order new battery cables may be having a bad connection problem???
But I'm still having issues with it's starting right. I'm still having to crank on it for a bit
When the WTS light is delayed the engine will not crank. The ECM turns on the fuel system when it lights. At least everyone I have seen with that issue has experienced that. It is a sign of damaged ECM. But with your cable issues and most likely weak  grounds, I would work thru those issues and pray that helps. Our electrical systems are pretty finicky about that kind of stuff. Next time the light does not light right away wait until it does light and see if fires right off.
Ok well tonight I will be putting new terminals on my cables. Lastnight cleaning them the positives cracked so I'm going to change them all tonight and see if it doesnt help. I appreciate all the help from everyone
Here is what I'm getting
No. Sorry the delay is caused by memory issues during booting.
Our ECM is just like a laptop computer on a smaller scale. It has a CPU, memory, hard drive (PROM) and a BIOS. So basically this all occurs in mere microseconds. When the key is turned on the BIOS tells the CPU to boot the PROM content into RAM and execute the first instruction which is Wait To Start light and grid heater (if the IAT is low enough). That lag your seeing is the bootup process going bad. During the boot up it has a checksum to verify the contents of the code is correct and when the checksum is wrong it reboots again till it matches. The ECM can't do anything till that bootup process completes.
What went wrong? Basically, the AC noise from a failed alternator abused the memory and other  components of the ECM this typically stems from people do the lame tin foil mod, or ground wire relocation (old school), or adding noise filters to the PCM for shifting issues (automatic). This give a fail sense of completed repair and the AC noise is just masked from showing. It still beating on the transistors and diodes of the ECM. There was a span of time we all though VP44 where weak and failed because of different reasons. Now knowing the AC noise issue and how to stop it VP44 and ECM failures are rare.
How to fix? The only solution is to send the ECM to be rebuilt by one of the rebuilders we have on the list.
How to prevent this from happening?
I would replace the alternator and verify the AC ripple voltage is a passing grade. Like our test of measuring the idle AC voltage at the BATT terminal of the alternator typically lands at 30mV AC which is passing. Full load test could be much higher. Now you can do the W-T ground wire mod.
The simple version...
Ok so what your saying is yes my ecm is failing because of the alt is what I'm getting out of this I did check for ac Noise but I'm not sure if I have my multi meter set correct I was getting 30 on the ~
V 200 acv setting is that the correct setting?
Ok thanks. Will any of these ecm builders let me buy one and send mine in as a core I use my truck daily for work and cant have it down waiting on shipping?
Just like you I had a lesser DVM and had to go for a Fluke, I found a Fluke 77 for $40 bucks on Craiglist. It works well. I would even try calling pawn shops for one.
Sorry but no. Because of the all the flash programming that is required to make it "fit" your truck. You could buy a used ECM and ask around for someone to flash it for you. Way too many version of software and options to just have one available.
I understand your issue but there isn't many solutions to getting around this.
Link I provided above. Give them your vin number and some money, they will program new ECM to your truck with latest software  ( you can also ask to eneible 3-cylinder cold idle) just so you have it for future. When you receive your new ECM swap them out and send yours in as a core.
Before you slap new ECM in make sure you're fix all your whiting issues, or it will not be warranted.
Ok well I just re did all my battery cables and will be getting my batterys and alt tested before install of a new ecm I found one for 400 for the same year and granny and the dosge house will flash it for 100
My spear ecm is only 3 months off on built date as my original and it had a different software on it. Trucks were identical.
