- Replies 11
- Views 2.9k
Mopar1973Man 2 posts
Marcus2000monster 2 posts
NIsaacs 2 posts
2000Ram2500 1 post
No reservoir was on this pump. Just a pump in a bag. The store clerk picked it off with his fingers and handed me the seal. No charge. Being nice I bought two quarts of power steering fluid. Guys like
Yes they are easy to reseal. On other module vehicles that use the Saginaw power steering pump I've seen leaks due to stress cracks at the bolt holes in the fluid reservoir. With the miles on
I was told by the guy at NAPA that all the rebuilt unit are prone to failure doesn't matter who you get then through now (AutoZone, RockAuto, NAPA, Etc.) So he's going to do a bit of magic and order a
Finally, I'll be looking into replacing the power steering pump. Not that it quit pumping. The reservoir is leaking. The seal between the pump body and reservoir can is weeping fluid out and leaving signs of power steering fluid on the floor after a night.
