iQuad Boost Readings Lower than Boost Gauge
Just curious if anyone has experienced this before. I recently installed a Adrenaline with iQuad on my truck. When monitoring the boost reading from the iQuad on my phone it reads about 3psi lower than my other boost gauge. I have a 0-60 Autometer elite, its not a junk gauge and has never been over pressurized since my truck is mostly stock so I would expect it to be accurate. Could this be a conversion thing with how the Iquad produces its boost number or a sign of a failing MAP sensor? Truck runs great no weird issues I have noticed just curious since if it is low all my fueling will be thrown down 3psi levels.
Thanks
  • Replies 50
  • Views 10.7k
  • please check the jumper on the box. FYI it is impossible for the ecm to see 36 psi at wot, that boost fooling curciut will not allow it.
  • Just curious about this. My truck never see 400-500* at idle, cold or warm. Mine maybe sees 300* on cold starup. The EB will bring it up in the 450 range. Idleing in summer time on warm engine i will
  • I dont know. After 17 years it kind of looked crappy to me. Still works fine best I can tell but most tlikely needs a rebuild. 455k miles on it+many hours of idle. Still no play in any direction in it
On 9/4/2018 at 9:54 AM, Mopar1973Man said:
Known problem mine is the same way. I'm also running expensive ISSPro EV2 boost gauge.
Also running the ISSPRO EV2 gauge in my truck. I'm showing about 15 PSI on the gauge when my Quadzilla shows 8 or 9 PSI. I have a new MAP sensor coming in tomorrow and will be putting it in to see if that changes anything. I'll keep you updated.
Edited by Cronus577
Just put the new map sensor in and now the quadzilla is reading the same as the isspro gauge. Feels like I got all of my low boost power back and the turbos aren't as laggy
I’ll get another map sensor and try it. I just installed the pillar gaugesast night and I think I need to do some checking for the I made a video so you could see what the egts and fuel pressure are doing. For the egts I took a temp gun and the manifold was reading 230 but this is what the gauge was reading.
glowshift is known for issues.  that is what I would check out first.
7DC4159C-F792-4477-9AB8-EA70AC8ADC1B.MOV
At idle when cold the truck should be around 400-500* on the pyro. When you installed the fuel pressure gauge did you put on a snubber valve?
Yeah I installed the snubber valve on. The wire I have double checked. The gauges are brand new just got them out of the box yesterday.
The quality of glow shift is not good enough for me to trust that it isn't bad out of the box.
I’m wondering if the sensor isn’t bad for the fuel. I adjusted the snubber and it runs at 18 then drops and then gos back to 18psi
Just curious about this. My truck never see 400-500* at idle, cold or warm. Mine maybe sees 300* on cold starup. The EB will bring it up in the 450 range. Idleing in summer time on warm engine i will only see 250 maybe 275.
Edited by dripley
Idling my truck sit between 230 and 250 all the time.
Well then, looks like I might have to dig around and see if there's an issue on my end. I've never seen anything lower than maybe 350 and that was in 15* weather in the middle of winter. Mind typically sits at 400* cold idle and 450-500 warmed up.
My thermocouple is in the back half of the exhaust manifold outlet to the turbo.
I have mine in the egt tap on the BD 3 piece manifold
 I would think some place in the vicinity of this?
Yup, almost exactly in that location
How is your turbo still looking so good after all these years and miles, mine was half rotten with only 150some k on it.
I dont know. After 17 years it kind of looked crappy to me. Still works fine best I can tell but most tlikely needs a rebuild. 455k miles on it+many hours of idle. Still no play in any direction in it.
So after doing some checking it is actually my fass that causing my fp gauge to read that way. So I’m going to call fass in the morning about it. Now my egt gauge I still can’t explain y it’s off. One of the guys I work with has one that he is going to let me use to see if it the gauge or not. I changed the plug on the to the gauge so that way I could use the quad if I wanted too. But by changing the end it shouldn’t have effected the reading I wouldn’t think would it have? Any thoughts?
You may need to modify your return to tank spring like this, so the ball doesn't get jammed in it.
Picture is from the air dog but you get the idea
