Po216, blue smoke from exhaust
- Replies 23
- Views 6.7k
Steven cash 9 posts
Mopar1973Man 6 posts
JAG1 3 posts
trreed 2 posts
Be careful some of these can be just as dry as the fuel itself. No to mention raising the cetane and reducing BTU's. After clearing 243k miles on my last VP44 with just 2 cycle oil I seriously doubt a
Basically, there are 4 ways of killing a VP44... Fuel pressure - Optimal is 14 to 20 PSI of fuel pressure at all times. Filtration - Double stacking filters like AirDog 150 and the stoc
I have owned this truck for 15k miles and almost 1 year. It has never given me an issue. I have just installed a Quadzilla Adrinaline on my truck yesterday I took if for a drive on level 0 and the truck acted like normal but then fell on its face and would not go above 10 mph in 2nd gear (6 speed) no matter the throttle position. No black or blue smoke on first drive. Drove it back home and checked all connections, all were good. I double checked the pump tap and there was no issues there. Before I installed the Quad I had a edge EZ on the truck and on the max power levelthe EZ never gave me an issue. Now when I start the truck it'll puff some blue smoke. If I rev it it will have a large puff of blue smoke followed by constant blue smoke at idle. The vp44 on this truck has been replaced at one point. The previous owner installed an airdog on it an it is working well. Is the Vp44 dead? Thanks in advanced for advice.
