N5600- Fuller 8406 swap
- Replies 46
- Views 7.8k
Blueox01 17 posts
NIsaacs 7 posts
Dieselfuture 5 posts
Chris O. 3 posts
If you like the sound of an old 275 Cummins with the roots blower and back draft manifold, you will like this old IHC KB12. This old guy has about 20 acres of antiques, mostly trucks and dozers. The G
Nope, only lurking on the forums from time to time Just been too busy reverse engineering CCD bus in our truck, Like today I just figured out which digit of VIN number is responsible for AB
It was fun back in the day but after hauling logs for 25 years (mostly 2 sticks) and this Ford for 33 years, (installed the aux in '85) the 6 spd is just simple. Plus, like I said, it has more power a
I originally had to swap these in a week cause was hauling stock trailers for a living,but 6 yrs ago I burned a hole in #6 cyl this time, I tried to do it right. Fabricated trans mounts using exiting trans mount locations in frame
