Filling oil filter when changing oil?
Well seasoned school bus mechanic tells me when they get somebody new changing oil it's only about 2 weeks till they stop filling up new filter with oil before threading on new filter without prefilling.  Interesting part to me was no failures that he knows of.  I fill mine but wondering if really necessary. Other than manual says so.
Do you prefill?
  • Replies 208
  • Views 31k
  • I will ALWAYS pre-fill an oil filter if possible.  Been doing this for decades and will continue to do so too.  The whole "you can pour something into the filter by accident and it will get into the o
  • Very interesting discussion gentlemen. It is good to see two folks of differing opinions have a sane discussion. Now if we could just get congress the learn that ability they they might be able to get
  • I've been trying to live by a new creed after 65 years and 44 years of marriage.   I stopped explaining myself when I realize other people only understand from their level of perception, not
Looks like it has the original oil in it....
Or he was pre-filling through the center hole :sofa:.
Above was a Ford flathead V8 :thumbup2:
What's this one ...? Its got a nick name too   ...:thumb1:    :smart:
Edited by GSP7
Here is a Easy one ,
!955 331 cu in _____________ V8,,, Fill in the blank :smart:
Who-what?.... 331 cu in ______________
2721897653_604f4eb70e_z.jpg?zz=1
OOPS sorry...... I got carried away and stole the thread
Edited by GSP7
Might as well throw a fender cover in yet before we get back on track :lmao:
On 10/17/2018 at 7:36 AM, Mopar1973Man said:
Ahh... So you admitting that petroleum oils won't exactly cause a dirty engine. This what I wanted to point out is too many make this false claim that synthetic is the only solution to clean engine. When the very same results can be produced with petroleum oils as well.
The top end of a 2015 Paccar MX-13 engine just after valve cover removal with 425,xxx miles on the engine and owner said about 60,000 on the 5W-30 Mobil Delvac 1 ESP. I didn't even know Mobil made it in that weight of oil. I just did a routine overhead adjustment it and I was happy I didn't have to spend 3 days scrubbing soot stain out of my hands and wrists. All diesel oil clean well because of the amount of detergents in them but in my professional opinion synthetics ability to keep the internal engine clean is superior especially in emission diesel engines.
Here we go with synthetic cleaning again. :rolleyes:
I never had any those problem with doing valve lash on any diesel where I had to scrub the soot out of my hands. Like even on my own I can just wipe my hands with a rag and then wash with soap and water and done. Again just plain ol' petroleum engine oil nothing special.
Now yes I've seen even what you are talking about where the oil is so full of soot that it like pen ink anything you touch is stained black instantly.
Probably because it's a thing
Your motor is basically 1998 technology/emissions... that's why. It doesn't put soot into the oil like new motor do.
The motor posted meets 2015 emissions, very big difference in terms of soot in the oil.
Some of it is just the physical design of the piston/injector that was used to meet emissions. The 04.5-07 5.9 piston puts LOT of soot into the oil, the 03-04 and 6.7 pistons not as much. The 6.7 puts soot into the oil, but not from piston design.
My point was this how an EPA13 level emissions engine overhead with mid life mileage looked without an overnight drain and was 20k past its petroleum oil drain spec. This engine is factory equipped with a centrifugal (spinner) oil filter also. No by-pass filters were on it.
That right there would keep any engine cleaner. I know those have been proven for YEARS to do a way better job of filtering out debris and soot over a bypass filter but typically a spinner filter is a pricey add on.
http://www.spinnerii.com/index.cfm/div/65/Industrial
Technically that could be considered a bypass filter.
So this isn't like a fair comparison being the spinner is involved.
OK kids,,,, what's this oil strainer out of?
:shrug:
Easy one
Edited by GSP7
air cooled vw
:shrug:
Good point... Spinner filters are considered by-pass filters even though they use no filtering media.
I know with the perseverance you have with dino oils there will be no way to convince otherwise. I was skeptical of synthetic engine oils about 15 years ago and thought it was just overpriced oil but after repeatedly seeing nothing but benefits with synthetics I made the switch and have never looked back. The only vehicle I own that still has dino oil is the 97 12 valve but it too will soon have Rotella T6 when I ever decide to repair some external oil leaks. Synthetic oil is expensive because you get what you pay for.
Anybody using a spinner?  If so how's it working out?
 I thought the lowest psi rated spinner operated at the our 5.9 max output.   In other words, not effective on our size.
Edited by 015point9
Typo correction
2 hours ago, AH64ID said:
Image result for nope gif
Here you go the actual washable performance oil filter for Cummins...
https://www.dieselpowerproducts.com/p-7960-hubb-reusable-oil-filter-89-18-dodge-cummins.aspx
Manufactures website...
https://www.hubbfilters.com/
https://www.hubbfilters.com/oil-filters/
Close this window
Oh... I really like your GIF there @AH64ID ... :lmao2::lmao:
You same reaction is the same reason I will never use a washable air filter these truck. The only thing I own with a washable filter is my Honda ATV which is the OEM air filter by Honda.
:shrug:
Easy one
VW beetle. From the 60's and 70's... Took a minute...
