Tubro NOT working, HOT EGT's!!! HELP!!!
- Replies 37
- Views 10.8k
idahocountryboy 10 posts
Mopar1973Man 7 posts
AH64ID 5 posts
KOYOTE 3 posts
Ok... I have been having a major issue with not being able to build more than 10 psi boost. I have been trying to fix it to no avail.
So, today was about 85*+ here. Drop down the high way and looked over... 1,200* EGT's!!! I was shocked! All week I had been running 600 - 900* even with these low boost numbers (10 psi max). Boost issues STILL There and now the heat issue too! I turned off my Edge, didn't make a dent. When I sped up a little it would hold or drop 50*. It wouldn't get over 1,200*, unless i was going up hill to the floor (and I pretty much have to do that in 5th to get up a hill with no boost
PLEASE!!! Any suggestions would be great.
So tonight i figured out how to do a turbo pressurized test from Moparman1976.
Now hooked the air line to it, first time it blew off...
so i lowered the regulator on the compressor. It Barely stayed on but did. Found a leak, or so i thought. The boost elbow is from Edge. I thought it was at the hose clamp, but after taking that clamp off and re-tightening it twice it is good. I did notice that the boost elbow had a small pin size hole in the 90* angle. What is that about? The air was coming from that, and not the hose.
I'm at a total lose. I can't find a leak. I didn't see my wastegate move. and I'm heating up faster than ever and for the life of me don't know why or how to fix it. Please help, I'm at the end of my rope.
