- Replies 64
- Views 13k
mountaindan 17 posts
notlimah 16 posts
JAG1 11 posts
Mopar1973Man 7 posts
@notlimah Probably won’t start with gas. Try some diesel ??
Fuel dumping into the fuel neck is a long way from the fuel basket. After the fuel meets and mixes with the fuel in the tank, its velocity is greatly reduced giving the fuel plenty of time for any di
Do you park your truck on flat ground, facing uphill, downhill? I had a similar problem only when I parked facing uphill. It also manifested on a very slight incline (1-3 degrees maybe) of the drivew
My truck is hard to start after sitting even for a short time. I have replaced the washers on the banjo fitting back of the head, the seals on the T fitting, and the fuel line to the tank.
I just pressurized the tank with air there are no leaks I can find anywhere. It has new injectors and new crossover tube O rings.still has the same problem. No fuel in the oil. Any suggestions from the experts?
