Intermittent strange high idle.
- Replies 39
- Views 7.2k
Marcus2000monster 12 posts
Mopar1973Man 8 posts
dripley 4 posts
Dieselfuture 4 posts
I adjusted the valves a lot. One head gasket. Lots of leaky valves, broken exhaust manifold gaskets, injectors, and stuff like that. Nothing on the bottom end other than the tappet cover leaking. W
I can tell you that @cajflynn was a driving fool. (In a good way) I heard from him 800-mile day if possible. I tend to believe the more you use it the longer it will last. I'm nowhere near the level o
I'm tagging along with @Mopar1973Man and @dripley with an easy 2.5-3k a month and running strong at 352k
I have noticed recently that sometimes upon cold start my truck will idle at 900rpms instead of the usual 825 rpms. Iv also noticed that when accelerating I can seemingly feel dead spots in the pedal at times. Could my apps be going out? I can rev the truck and it will still idle high but when put in gear and driven and stopped it’s back to 825. Thoughts? Also I had a P0336 come up and replaced the crankshaft sensor with a Napa part and code went away along with the symptoms so that’s out of question.
