- Replies 12
- Views 2.1k
Mopar1973Man 4 posts
dripley 2 posts
JAG1 2 posts
Silverdodge 1 post
Popular Days
Recharging drained batteries by driving around or idling put a heavy load and strain on the charging system and should be avoided. I don't think you could put a full charge back into the batteries an
I would personally use a charger and disconnect battery's over night. As weak as these alternators are i would not take a chance driving around, kinda gambling there.
MoparMans negative cables need disconnecting.
Well guys I did a damn fool thing I left my key on in my truck last night and it drained the battery is overnight the truck was off but I left the key on I unplugged the quadzilla this morning to jump-start it it took two cars to jump it and I let it run for 30 minutes and drove around the city block but I had 14.2 volts before with the new batterys now it's 13.8 how long would it take to fully charge it idling it was above 25 last night
