- Replies 30
- Views 3.5k
JAG1 7 posts
Mopar1973Man 5 posts
dripley 5 posts
Bullet 3 posts
If it ain't broke, don't fix it. 290k on my RV's with no issues in sight. Smooth cold start with no blue smoke and no blue smoke on a long down grade..this is my "bar" test
Looked all around for the dang thing........ Naw............ can't be.......... could it? Got flashlight, guess what ? It down the intake
That was my thought on my starter bolt, i can fell try start but it just wont quite do it. Surely the old bolt not broken off. Yeah, just keep telling yourself that.
Bet my morning is worse than yours! Started up the truck to go to the gas station for a drink. Coasted out to the main road, pressed the skinny pedal, blue smoke, no power. Turned around, went back home, checked for codes. The code that we do not want shows up. 0216.
Guess can't complain, 190k miles on this pump. If I am going to have to prime the fuel system after install, then it is a good time to replace the injectors! Time to look at all the info for a pump replacement and injector installation!
