A/C blower conversion
So I searched a whole lot, maybe I have just been unlucky, but I have not found a better blower option for 2nd Gen A/C blowers. My brothers 4th Gen pushes much more air. I am not looking for colder air. I just replaced my entire A/C system. I want more air. I dont care that the system was designed for the stock blower. Has anyone put a 4th Gen blower in a 2nd Gen? Or is there a better blower? Maybe wire the stock pig to 24v?
  • Replies 64
  • Views 15k
    With my average distance per year at 60k miles about every year or 1.5 years I'm changing coolant. Full block flushing with clear water and reload with fresh coolant. Basically, either test with pH st
  • Was this anything close to what you were wanting for measurements?  Disclaimer: these are approximate measurements... please dont bring these numbers to a machine shop...
  • Celtic Clamper
    Celtic Clamper
    Brand new. I pulled the entire dash and box out. Even installed the Heater Treater. I also vac checked the function of all the doors, and used my power probe to function test the blender door. Al
I also vac checked the function of all the doors, and used my power probe to function test the blender door. All speeds work on the blower, I just want more air flow.
As for different blower... Don't know. :shrug:
Your the only one I've ever seen requesting for more air flow.
I researched this a couple years ago and same thing I couldn’t find any better options.
Thanks.
You need more ponies in that blower motor, maybe we can come up with a big bore kit... :lmao2:
Might look at the voltage at the blower. See how much voltage drop your getting. Check the voltage while running on HI and back probe the plug if possible.
It's been a long time age, so my memory may not be up to par. As I recall, someone on www.dieseltruckresource.com adapted in a blower and motor from a Chev pickup.
Thanks. I tested it with my Power Probe, force feeding it, and almost have identical rpm. It is about the same as a few other second gens I have been in. I think it works correctly, I just want more wind than I think its capable of. To the point that I usually have a cowboy fan hanging on my passenger visor. I know people have been complaining of the same problem on Mega cabs. If I get something that pushes more air I will have to use the "Big Bore Kit" in its name! I have only found Chevy conversions for the 1st Gens. I will probably just make do, or keep the windows down. Thanks again.
Edited by Celtic Clamper
Wonder if you can somehow modify incoming air to the cowl and directed towards the blower hole
Ram air hood scoop for AC! I like it!
I would look at a way to increase the blower RPM.
Maybe make the fins on the blower a tad larger?
What's your resistance at the plug before it goes to motor? If any?
Stanley, do you mean voltage at the plug or maybe ohm out the motor? Mike, thats what I am looking into first. Easiest is to increase rpm, then look at different blowers, or give up and buy a 4th gen. I wanted to wait another year or 2 for the 4th Gen. I will continue on the 2nd Gen because I do not intend to ever sell it.
Mike, glad to hear you are doing better.
RPM loss will occur. You have not increased the HP of the motor to blow more air so, a bigger blower is just going to run slower.
Ohm something out has to be disconnected. Ohming the windings isn't going to do much.
I would be looking at the voltage at the blower.
Just some simple theory and math... You can draw the same 20 amp but at different voltages and the workforce will change. This why I'm looking for power issues first before modifying the blower cage. If the motor is underfed and the blower cage is increased the flow will decrease too because of the lack of power to twist a heavier blower cage.
watts (work force) = volts x amps
240 watts = 12 volts x 20 amps
280 watts = 14 volts x 20 amps
So if the voltage is lower than battery voltage on high this means there is voltage drop between the supply and the motor. You would have to insure that the blower motor was capable of getting the same voltage on HI fan as the battery is running.
I think I was a little hasty in that reply and didn't think what I was typing haha :doh:
Yea - the voltage was what I was trying to get at. Voltage at the plug before entering the motor, IE is there a "resistor" inline before hand lending you 10v? 8v? etc.
With ohms, I usually just check it to see what resistance I have if any. Check for possible shorts etc. Always check your wiring (condition, routing, grounds, corrosion, etc) it can help either narrow down your issue or help you navigate possible causes and solutions.
Is the blower capable of more voltage with out burning down?
It may just be simple as splitting the blower from the motor and adding a gear box in between? With in this same statement if the motor just isn't cutting it then this fabrication would also allow you to install/change out a different D/C motor
First off on HI there is no resistor. This why I want to be sure same voltage of the battery is present as the blower is on Hi and engine running. So, charge voltage is 14.5 Volts then you should see 14.5 or very close at the motor on HI.
I am pretty competent in electrical. I have not checked voltage at the plug. Because I checked rpm while powered through the switch and while being fed from my Powerprobe, and they were almost identical, I can assume that my wiring is all in relatively good condition.
The squirrel cage could possibly be changed. If the motor was engineered a little oversized for warranty/service duty reasons, then there is potential power available for a slightly larger blower. If it is already maxed out, then in fact the extra power required to turn the larger squirrel cage will cause less air flow and burn up the motor. If the spec's check out, maybe it needs 24v to make it a hurricane.
That said, I am looking into motor spec's and options. Once I finish spec'ing the stock blower, I will find a suitable more powerful blower assy, or faster motor with same other spec's. This will fix my flow problems.
The main problem lies in that based on my expirience with air flows, I will need about 20%-30% increase to actually feel the air in the manner that I am expecting.
Like I have stated, I am fairly confident that my stock system is working as engineered. I have cleaned the entire ducting, replaced most foam, and just finished going through the a/c system.
I was just hoping someone had already done the leg work. Now I just need time off from work.
The fan in my bride's dually was blowing lazily, so we swapped a couple different used ones into it to see if that would help.  No improvement.  I finally bought a new fan motor for it and that fixed it.  Now it blows like how I remember them blowing when these pickups were new.
