No fuel pressure but Fass pump is working.
- Replies 36
- Views 11.2k
the7t7 11 posts
Mopar1973Man 8 posts
dripley 6 posts
int3man 3 posts
Suggestion. Take that plate off and pull the plug loose from the plate. Now zip tie the plugs to the loom on the cowl. You'll find they move over towards the driver side a bit more. Then they are alwa
You could just put battety power to it first and see if runs properly. The bad thing with bypassing the ECM is you loose control of it shutting the pump down in case of a wreck and you are knocked out
Yes, it's true it will start and run without a lift pump and drive at low speeds for safety yet. So does the AirDog pump and it will still suck fuel through the pump and run.
So I was driving around testing my new 7x.012 injectors and new quadzilla and my truck died. I tried restarting and it started right back up. Fuel pressure from my Fass seemed a little low (around 12 or or 13 psi) but otherwise everything seemed like it was working ok. I made a stop for about 20 min and when I got going again the truck died again 100 yards down the road and wouldn’t start. I noticed that the pump wasn’t cycling on key on/ starter bump so I had the truck towed back to my shop. When I tested the pump by putting 12v to it, it worked, so I replaced the relay with another but couldn’t get the pump to cycle. I then tested the ecm signal lead and I was only getting 6v at key on and nothing higher when I bumped the starter. I did notice that when I bumped the starter the voltage went to open line and then back to 6v. I don’t think 6v is enough to trip the relay. So do I have a bad ecm now? This would really suck since I just replaced it with a reman from ACS. Any thoughts?
