Stuttering during free rev
- Replies 14
- Views 2.6k
Me78569 4 posts
Ravewolf 3 posts
Mopar1973Man 2 posts
kzimmer 2 posts
Popular Days
I don't think it's normal. It's a hard sputter. Something isn't right. The only codes I have are the boost code from the quadzilla and the apps sensor code. With the way things are going on this truck
Just for verifying. Unhook the Quadzilla completely. (Wire Tap, MAP sensor, and CANBus). Then try again. This just leaves you back to stock ECM. If its still doing it with the Quadzilla th
As the title states, she pops and stutters when I free rev her. Has done this since day one of when I bought the truck. It doesn't do it under heavy throttle, or when I'm cruising steady,just when it's idling and I rev it.
I figured it was the junk edge tuner, and a new tuner would help. But it still does it, even when warm. It does puff gray smoke when it stutters, but clears up after a few revs. It reminds me of having a car with a carburetor that has a stuck float, you have to rev it because it "loads up".
What could it be? MAP Sensor? My cel is on but it's from my apps sensor, and I have a new one ordered. Even before when there were no codes it still stuttered like this.
Could I tune this out on quadzilla?
