- Replies 146
- Views 20.4k
Marcus2000monster 41 posts
Mopar1973Man 34 posts
Me78569 28 posts
trreed 10 posts
Step #1, is to understand the tuning. you need to read the below article and understand what the tuning variables do. If you are not willing to put in time to tune your truck, then it
Don't play with wiretap until you get your canbus fuel map adjusted properly.
They abandoned Tfarao's truck, it was still stuck on lvl 1 when he got it back. I can't remmeber much about it, but I think tyler said it wouldn't do more than 10-20 mph the way it was.
Well finaly got my qaudzilla back. They replaced the circuit board and sent a brand new wiring harness.Reinstalled it last night and now have some different issues. First off i now have a whining noise at all times that follows engine rpm. Second my truck idles a bit more rough with it installed and when free revving the engine at about between 1k and 2k rpm there is a dead spot in the rpm band. i can stomp it at idle and it will just drop out and come right back. When returning the tune level to zero it idles and revs perfect. Wht the heck is going on? This is stock v2 tuning as well. Havnt started the custom stuff yet. The rpm issue also does it under load. I will get on it and it will hesitate a tiny bit and go again. Please help. Thanks
