Chassis Ground Question
- Replies 16
- Views 12.1k
It all SHOULD come back to the battery. And that is the OPs point. According to the FSM so far that we can see, the main grounds go to the block. The two other items that we consider groundable ar
Don't forget the 4 sensor grounds that are not soldered nor crimped together, they are only fused together with some sort of plastic from the factory. . Last time i heard plastic was good for solderin
Herd are the sensor grounds @JAG1 was refering to.
Hey guys,
On our trucks (01 specifically), how does a chassis ground return to the battery.? Lets I add a set of aux lights, or anything really, and I ground the piece to the frame or body. I know there are the two battery to body grounds on the drivers battery, and one (if I remember right) on the passenger battery. Are there larger ones from block to the body or frame somewhere? The reason I am asking is I am curious if you add something that has a little bit higher of an amperage draw (grounded to the frame)
if there is enough ground going only through those body to battery (smallish) ground wires.
Thanks
John
Edited by JHFIII
