Oil from breather tube
I know its been asked so forgive me, but I have done the Moparman mod and before I took my truck to the body shop I got maybe one drip of oil from the tube after 4 months with the mod. However after I got my truck back it drips after every trip. Just a small drop. I did the blow by test and it Is perfect. Is this normal or something I need to look into? Thanks guys!
  • Replies 29
  • Views 6.2k
  • If you do decide to put a bottle on it to catch any dripping, just make sure it vents.  If it is sealed up tight, you will prevent the crankcase from venting and can cause other damage and likely more
  • Dieselfuture
    Dieselfuture
    Gets even worse vacuum leaks
  • Tractorman
    Tractorman
    The two times over the life of my truck that I noticed the breather tube was messier and leaked more oil than normal, I had a vacuum leak.  Neither time was the vacuum leak large enough to noticeably
I've got about 3,500 miles on this oil change and my oil level drop a whole 2mm on the stick and resting on the full mark exactly. My last oil change I was just a just that 2mm over the full mark. I'm not going to even sweat it.
Yea my oil level might drop a little bit but nothing I have really gotten to concerned with expect one time when it dropped maybe an inch or two, I think I was on a few to many steep down hill grades.
My 98.5 24V has a hose that comes down and ends up near the front pinion yoke. I did not like the slight drip from my diff pinion area. I thought it was the pinion seal. I changed the seal and cleaned everything up. Then I extended the hose slightly longer so now the drip comes off lower down past everything. Straight to the ground. About a small spot about the size of a quarter drips out after each drive. It does not ammount to much. Just an annoyance on my driveway. I get out there with some heavy duty degreaser, a scrub brush and a hose every few months and clean up the spots. My diff and pinion are staying clean too now!
Before I rerouted mine I thought 2 times for sure that my front diff was leaking. Haha spent a good bit of time both times looking for it too.
Just look what the big boys leave behind at a fuel station what you see is normal.  I knew something was afoot when I had more than one drop not by the tube, how I found out my front main seal is weeping.  On the tube though does anyone notice how it seems to get worse come summer time not much but noticeable?  Wondering if heat and condensation play a role in making the drips larger than if it was just oil because I will admit that I felt the fluid on the ground and it did seem thinner than straight oil.
Actually it will get worse if you crank up timing excessive or in the winter time with a canned tune like Edge. This is because as IAT falls below 80°F it cranks up nearly 4° of timing advancement. Then add high cetane fuel will add to the problem in the winter. Typically gets better in the summer.
The two times over the life of my truck that I noticed the breather tube was messier and leaked more oil than normal, I had a vacuum leak.  Neither time was the vacuum leak large enough to noticeably affect vacuum operated controls, but the excessive air flow showed up through the breather and added to the mess.
Each time I repaired the vacuum leak the breather began venting normally again.
- John
