Rolling through Craig's list see a s03 for 250. It's an older add he says he still has it. I'm like ****.
I ask if I can take the programmer for a spin. Get it loaded on 9 and he rides with me.  Get out on street and stand on it , I'm like **** I wasnt expecting that. Hes like what turbo is that it whistles he thought it was something cooler then a stock hy35.
Pretty much roll around the block. Pay him and we go on our merry way.
7x09 injectors + s03 = fun
Edited by Evan
  • Replies 191
  • Views 28.6k
  • Rather than spending ~$600 on head studs, you should sell the s03 and put $400 of the $600 that you would spend on the studs to a quadzilla.  3x the power and you can tune timing to not blow the head
  • Good drawing!  It reminds me of the crazy/hot matrix.  A must see for us dudes...
  • I would warn against being too throttle aggressive down low with a S03, it does not pull timing at heavy throttle low RPM which can result in head gasket issues.  The chance is higher since you have a
I rarely run hardly any throttle
I'm still on SW5 tm4 t4 d3
I cant tell any difference in egt. I think with timing it is spoiling quicker under 10psi on freeway I saw some prett steady 5psi stretches but due th o wi d and rolling hills and some surging it would still almost hit 10psi.
Yes smokes before turbo lights. Leaving a stop light under light throttle it's a heavy haze then cleans up into light haze.
I might email mads and see if theyl send they're fuel curve charts for sw settings. They gota give up more then they have.
I'm alittle Leary but I do want to try towing on this on sw5 with 4 timming..
It drags shifts out under lower tm because the trans is shifting with more TV pressure.  Changing settings is almost more or less like tightening and loosening the cable.
Theres si much to notice and feel tunning a auto truck compared to a manual.   And yes its hard to figure what to notice and feel. Very challenging.
Thanks again
Glad said you had a dead spot with high duration was starting to think it was just me.
Two things here control that haze, TM setting and the pop pressure.
good luck with that, I've tried and had no luck either.
With a lower TM and a higher Timing on SW5 you will notice a huge change in spool up.
Honestly, I've never been able to understand why this is. But Its one of those things where the TM will effect the torque out of the motor, and for some reason the shifting. I've had the truck operate smoke free on TM2, but I had to spend a stupid amount of time adjusting my TV cable. So I found that TM3 is the best base to start from.
Not to mention your running a HY-35 which also effects temperatures and spool up.
Thanks again
Yep, not a problem, but like I said I haven't a clue what causes it, I just know that turning the D down solved it, and the passing smoke as well.
Higher tm the truck moves down rd quicler with less throttle means the TV lever is moving less creating less pressure for speed wich shifts sooner.
Lower tm more throttle ti fo same speed moves TV cable more.
This just happened in that order rock kissed pumpkin bent fo control arm removed pump.
Going 5mph blind into the sun.
So far temps dont seem to be affected by tunning.  Same with or without timming
I just got pump tigged jack up and it's still working. Drilled holes for the upper 2 bolts and drilled a few holes to use a welder spark plug cable to secure the bottom of the bracket
That sucks. Glad i stay in PA/NJ and deal with non-dirt roads.
Dead spot in the power band is definitely gone. Pulls noticably harder from 1500to 2000.
Swapped my 33s off for my good 35s surge on freeway is much better and psi is a pretty solid 6is woth 33s needle was bouncing from 5-10ish.
Pulled horses and she still smoke on heavy side taking off from a stop under normal to light throttle  then hazed through to 1900 cruising.  I think slight haze st 1900
Towed 9k at 1900 rpm plenty of power to spare can stand on it roaling coal and be doing 85 in fast lane to jump ahead of the acasional truck or grandpa going slower than me.
Still smoking plenty off idle with a trailer I can see cars behind me going through my cloud across they're windshield.
I almost think it started smoking more in the last couple days and I haven't changed any settings.  Still sw5 tm4 t4 d3.
Might drop d to 2.
Does the factory computer learn the driver I think it does learn driving characteristics of the driver adjust or adapt whatever you call it. Am I crazy thinking that? If it does does it still do that with the smarty tune going? What about the quad?
Maybe I read something about adaptive parameters and my mind just moved it over to the truck
Might drop d to 2.
Back your TM to #3 and see how the off idle smoke is.
Do you think it has more power now with it on Revo then before when you left the Revo settings on the SW#
1 hour ago, Me78569 said:
the ecm doesn't "learn"
its just the smarty being smokey
Yes indeed, but that I think too deals with injector pop pressure.
Pop has way less to do with it than duration command does.
Yes it has more power because revo is set at tm 4 sw5 tm default is 3 sw6 tm default is 4 feels the same as it.
Not sure I believe the sw# brings different fuel curves. I still think only tm# does sw is nothing more than a default set of revo settings. Only thing changing with sw# is the tm# and that's what changes the curve the tm # not sw. Lol I make no sence and am probly wrong just what it feels like to me.
I like how tm4 feels off idle compared to 3 I'll deal with the smoke I have messed with it but I'll put duration down a number. Was going to change tire size earlier but even that I'm not sure works. I have speed limiter set at 85 and can easily smoke way passed it. I think I have 32" tire plugged in so not a huge difference to 33" anyways
It did for me. My smokes issues went away at 322bar. And the settings weren't changed at all. Not only that but the trucks response was more aggressive. Aggressive to the point on sw9 I can actually break the tires lose on the highway.
I think the pop pressure helps by changing the injection point and the duration is shortened as a result.
But with the smarty locking timing, it's effects are so significant to me that it made a difference.
I put D to 2 and holy crap seems to pull harder all the way through. I think I'll go down to one or whatever factory is.
D2 made it crisper quicker revving very noticable even under light throttle. Still smokes but manageable. If I have to dive in traffic from a stop I'll leave a black cloud.
Gotta remember i tested pop pressure back to back running the same tunes.   Going from stock pop to 350 bar resulted in being able to throw ~%5 more duration command to the truck before smoke appeared.  I was still having to pull %30 duration offidle to keep the smoke from occuring.
The run are on youtube. If you want to compare what pop pressure did for smoke output.
I wont be doing injectors or a quad till tax time if then.  Happy with the power fuel mileage the smarty is getting.
My truck smokes with the factory tune and boost fooler so it very well could be injectors.
Also need to do steering and swap ro all soft transmission lines. And my turbo has more oil residue and some shady play. It may decide to be priority
Yes, but you weren't running a smarty at the time either if I remember correctly.
I really think that resisting the pop offsets the smoke production.
I'm just saying that for me going from 280 bar to 322 bar solved allot of my smoke issues. I can pass a SNAP test with a smarty. That's unheard of.
280 to 322 bar is a 622.8 psi increase in injection pressure this will atomize the fuel better therefore the rate of burn will be faster and more complete hence why bad injectors dribbling cause a lot of smoke the flame cannot move fast enough across the cylinder to complete the burn before exhaust valve opens.
293 bar is the lower limit for injectors. Below this the spray is not as good and larger drops and less fine mist.
every injected engine has a low limit even petrol/gas and they do vary, usually the smaller the holes the lower the pressure can be as it's going to atomize through smaller holes at lower pressures than larger holes and note the word atomize... this is not mist and can quite easily penetrate skin, flesh and bones and cause at best blood poisoning and at worst death, if an injector is outside the cylinder for a pressure test you get mist right at the edge of the fuel cloud when most of the energy has dissippated, at the nozzle it becomes dangerous as 322 bar is 5000psi give or take, over here in the uk it is illegal for the old fashioned injector testers which were high pressure mechanical pumps which were supposed to be full of a fluid that mimicked diesel and didn't burn but they never were, the injector was fitted to an old injector pipe of the same thread and away you go, now they have to be tested in a cabinet with the correct fluid with no way of getting any part of body inside the cabinet while it's tested. Even cracked injector lines are dangerous if the injection pressure is generated at the pump like a P pump I suppose, best to crack them a lot and never just a gnats, most everything I see now are unit injectors and thats take em out and change them usually in Cat C32, C18, C13,C9 and C7
Two reasons I open mine all the way #1 the pressure is dangerous as you say, #2 I dont want the mess with the diesel spraying. My engine bay is dirty enough. I open mine all the way when repriming. Once I ses a good flow I close it up.
