Looking for some help making a tune for 7x10 sac injectors and 56/62/12 turbo.
Ideally a race tune and a DD tune
I run 315/70/17 tyres and 3.55 gears im struggling with EGTs climbing.
Can someone help me out with a basic tunes I can work with?
My altitude is sea level too 1000ft above there abouts.
I have a 4inch straight pipe too.
Quadzilla V2
Thanks
  • Replies 37
  • Views 5.2k
  • Dieselfuture
    Dieselfuture
    These rims and tires waight over 400lb I man handled them, actually I made the rims too. I still got around 10mpg on this truck running about 60-65mph with 454 BBC 500hp. I did have 6.72 gears
  • These tunes are all geared towards 7 x .010 ish size injectors.  Please run them and tell us what you dont like and we can adjust from there.
  • Ronniemx3
    Ronniemx3
    Excellent I will try them over the next couple of weeks and see how it goes I'm just pricing some smaller tyres and put my spare ones up for sale ?? I'm going for a 275 70 17 I think now. It wi
Gear ratio is wrong and too low. Need to re-gear the axles or change out the tires. You'll need 31-inch (3.55) or 30-inch (3.69) tires for optimal ratios. EGT will naturally fall with ratios between 3.55 to 3.73.
My current tune would cover you for the Daily Driver. My turbo is slightly bigger (60/60/12). I'm already running 7 x 0.010 injectors but mine are popped at 320 bar for economy purpose. I'm 1,800 feet to 5,000 feet typically.
I'm going to release another version here soon. Being summer fuel is in full swing and I can run even more timing. I just tested to see how much timing I can run. I'm pretty well maxed out now.
1 minute ago, Me78569 said:
Have you looked in the tune repository?
I did but didn't find anything too close I copied a tune that I see posted on here in 2016 but I'm still struggling with egts on hard pulls! It runs awesome just egts are making the quad back down
Yeah it's a shame as I love the tall tyres! I have a spare set of the 315s too so I wont be going smaller anytime soon any other ways to help bring egts down for the time being?? Other than a re gear as that would be a fortune to do over here ?
The truck runs great with these injectors I'm really happy just want to cool her down some.. thank you.
Gear ratio. Strictly gear ratio and tires are too big and adding way to much engine load. I've got the tune dialed into the point I can WOT all the way to 100 MPH and never reach 1,200*F. But then again I'm running a mere 30-inch tire but the ratio is correct.
Might look cool but your just going to burn it down with those huge tires. The only way to keep those tires is to re-gear the axle with 4.10 gears.
I will burn these 2 sets off and go down too a 285 or so thanks
285's isn't going to be optimal either. Still puts you at 3.44 on the final. Need to go smaller yet. This will impact the EGT's still not as bad but you still adding quite a bit of rolling resistance. Even with 285's you would be optimal if your re-gear with 3.73 gears.
More on rolling resistance...
http://hpwizard.com/rotational-inertia.html
Yeah but it will be a fair bit better than what's on now. Re gear over here is well over priced so i will keep coming down on tyre sizes... this tune you sent is it safe to beat on
I love my new 265/70/17 for ease of taking off, getting up to speed, and the bump in MPG, one thing I'm not liking so far is my cruising MPG, seems I was getting better MPG crusing at 70-75 with 285/70/17 close to 18mpg latly same speed with 265 I'm down to 16mpg. But if I slow down to 60ish I'm closer to 22mpg where with 285 I was at 20, still pissing around with temperature differences and may adjust my tune a little more.
I'm going for a 275 70 17 I think now. It will be nice for some hard acceleration again! The 315s really took the legs out of my truck although with these 150s and turbo set up they break loose which they didn't before hand
245/75 R16 empty truck 20.84 MPG, when towing my RV 14.93 MPG. (recent numbers)
My 66 MPH is exactly 2,000 on the tach and this thing climbs mountains like a beast. Even the RV back there it doesn't slow down and doesn't get hot.
Nice I.went for 285/65/17 size tyre will be fitted Thursday
My current tune looks to be able to reach nearly 22 MPG then still on the 245's. If I can do it twice ill release the tune for download. Find out more when I fill with fuel today.
Not a huge difference between sizes so hopefully egts stay in check!
Size is only half of it. Weight is the other part. 285's typically are close to 90 to 100 pounds a tire with the wheel. The rotational mass has a minus in there too. This why ricers beat us hands down. Small tires and little rotational mass.
All you can do is give it a try it will definitely be better than 315
Yeah they are a lot lighter than the 315s ? then things are like a lorry tyre
These rims and tires waight over 400lb I man handled them, actually I made the rims too. I still got around 10mpg on this truck running about 60-65mph with 454 BBC 500hp. I did have 6.72 gears post-1102-0-16618700-1424623414_thumb.jpg
Thats a beast DF.
1 minute ago, dripley said:
Thats a beast DF.
I still know the guy that bought it from me, he takes it out once in awhile. I can probably buy it back butsadly  have no place or time for it now.
