- Replies 19
- Views 3.9k
dripley 4 posts
Marcus2000monster 4 posts
Mopar1973Man 3 posts
jag 3 posts
It is the caster you move to do this. My understanding is you can move them all the way forward and be safe with smaller tires. I am by far not the expert on it. Going to move mine forward one day whe
Be careful... If done wrong you can change the thrust angle of the truck causing it to pull to one side or another. I would suggest having an alignment shop do this and ask for more caster angle added
Caster bolts. No camber adjustments on the 4wd. It is fixed. Below is an example of the bolts you need. https://www.rockauto.com/en/catalog/dodge,2002,ram+2500+pickup,5.9l+l6+diesel+turbocharged,
Not 1 picture of this project.
Removed the 2 1/2" front lift, installed a set of 3" drop shackles in the rear. Replaced shocks, steering box, pump, upper & lower control arm bushings, sway bar bushings, track bar bushings, end links, bottom steering shaft bushing, plus installed the 4th gen steering components & brush painted every thing with black tremclad rust paint. Ball joints were new about 20,000 km's ago. Now I know I will be able to keep this thing out of the ditch with the Quad installed, well maybe.
